Use of Signed-off-by in MPICH
I'm confused by the current use of Signed-off-by tags in MPICH. Is this intended to be a developer's certificate of origin (DCO) following the model of the Linux kernel [1]? I can't tell if IBM is using it that way, where Michael Blocksome is the one authorized by IBM to assert on IBM's behalf that the work has clean IP and may be distributed under the MPICH license. But what does this mean? commit 87b20136ac20a0fbcffd8e29edcc500fcebbfc22 Author: Pavan Balaji <[email protected]> AuthorDate: Wed Jan 1 19:33:36 2014 -0600 Commit: Pavan Balaji <[email protected]> CommitDate: Thu Jan 2 15:39:07 2014 -0600 Move default eager threshold setting to ch3. We were setting the default eager threshold inside nemesis, instead of in ch3. This was causing other ch3 channels, notably sock, to get a garbage default value for the eager threshold. Signed-off-by: Wesley Bland <[email protected]> If this were a DCO, we would interpret it as meaning that Wesley is the one certifying the IP, but Pavan is the author. Or is Signed-off-by being used where Reviewed-by would be more appropriate? [1] https://www.kernel.org/doc/Documentation/SubmittingPatches
participants (1)
Jed Brown
