Re: [mpich-discuss] mpi_comm_spawn - process not destroyed
Hi Min,attached are configure and make logs for the build that I did for myself on our local cluster with Intel compilers. I.e., build is definitely not guaranteed to be perfect/optimal. But please keep in mind that I get the same behaviour with standard MPICH package in Fedora distribution - I think that configuration options should be available online, maybe prepared by someone from MPICH? Also, I tested with simple c++ hello world like program and it's the same. Thank you.best,stanislav. On Sun, 2017-08-13 at 19:58 +0100, Min Si wrote:
Hi Stanislav,
This seems interesting. Could you please also attach the MPICH config.log ? You can find under the directory where you build MPICH. I will look into this problem then and keep you updated.
Min
On 8/11/17 1:31 PM, Stanislav Simko wrote:
Dear all,
I'm just trying some very basic stuff with MPI_COMM_SPAWN in python (i.e. I use mpi4py package), but I see behaviour that I do not understand - the child process gets spawned, does its stuff and then "should" finish. I see though, that the process created for the child stays alive. I see this only with the MPICH, OPENMPI does what I would (naively) expect. In this way I can end up with N "ghost" process, after calling SPAWN N- times. My minimal working example is following:
______________________________________________ parent.py
from __future__ import print_function from mpi4py import MPI comm = MPI.COMM_WORLD spawned = MPI.COMM_SELF.Spawn(sys.executable,args=['child.py'],maxpro cs=1) print("parent process is waiting for child") spawned.Barrier()
______________________________________________ child.py
from __future__ import print_function from mpi4py import MPI parent = MPI.Comm.Get_parent() # just do some stupid stuff that takes a bit of time for i in range(5000000): a = i*i+1-(i*10) + math.sin(math.pow(i,i%8)) parent.Barrier()
I run with e.g.: mpirun -n 1 python mpi.py
Do I miss something with SPAWN method? (I tested on two independent systems, our local cluster with mpich v3.0.4, and my laptop - fedora 26, mpich v3.2.8 from repositories)
thank you very much for suggestions.
Regards, stanislav.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Stanislav Simko
