Re: [mpich-discuss] Hydra fills in the MPIR_proctable[] incorrectly with multiple processes per node
A standard response in this situation is to ask you to use MPICH 3.0.x instead of a version from June 2011. The MPICH guys can create a Trac account easily if appropriate. Best, Jeff On Mon, Mar 11, 2013 at 2:59 PM, John DelSignore <[email protected]> wrote:
I'm pretty sure this is a MPICH Hydra bug, but I wanted to ask this group before I go through the trouble of figuring out how to file a MPICH bug report, which I think requires me to create an MPICH Trac account, which I don't know how to do.
As far as I can tell, Hydra fills in the MPIR_proctable[] incorrectly with multiple processes per node. The index into the MPIR_proctable[] is supposed to be the MPI process's rank in MPI_COMM_WORLD. To demonstrate this problem. I created a simple MPI "hello world" program where each MPI process prints out its rank and pid; I attached it to this email.
This is the version of MPICH I am using:
shell% /home/mware/argonne/mpich2/1.4.1p1/x86_64-linux/bin/mpirun --version|head -3 HYDRA build details: Version: 1.4.1p1 Release Date: Thu Sep 1 13:53:02 CDT 2011 shell%
I ran the code under TotalView using 2 nodes and 6 processes (3 per node). I enabled logging so that TotalView would output the contents of the MPIR_proctable[] as it extracted it from the mpirun process. Here is the output of the run:
shell% tv8cli \ -verbosity errors \ -x15 \ -parallel_stop no \ -debug_file debug.log \ -args \ /home/mware/argonne/mpich2/1.4.1p1/x86_64-linux/bin/mpirun \ -hosts 127.0.0.2,127.0.0.3 \ -n 6 \ ./mpichbug d1.<> dcont Hello from rank 0 of 6, getpid()==2691 Hello from rank 1 of 6, getpid()==2729 Hello from rank 2 of 6, getpid()==2693 Hello from rank 3 of 6, getpid()==2730 Hello from rank 4 of 6, getpid()==2694 Hello from rank 5 of 6, getpid()==2734 d1.<> quit -force shell%
Grepping for "proctable" in the debugger's log file shows the contents of the MPIR_proctable[]:
shell% grep proctable debug.log mpir_proctable_t::create: extracting hostname/execname/pids for 6 processes mpir_proctable_t::create: MPIR_proctable[0]: host_name(0x0056be20)="127.0.0.2", executable_name(0x0056be80)="./mpichbug", pid=2691 mpir_proctable_t::create: MPIR_proctable[1]: host_name(0x0056be00)="127.0.0.2", executable_name(0x0056bde0)="./mpichbug", pid=2693 mpir_proctable_t::create: MPIR_proctable[2]: host_name(0x005859a0)="127.0.0.2", executable_name(0x0056c080)="./mpichbug", pid=2694 mpir_proctable_t::create: MPIR_proctable[3]: host_name(0x005856b0)="127.0.0.3", executable_name(0x005856d0)="./mpichbug", pid=2729 mpir_proctable_t::create: MPIR_proctable[4]: host_name(0x005856f0)="127.0.0.3", executable_name(0x00585710)="./mpichbug", pid=2730 mpir_proctable_t::create: MPIR_proctable[5]: host_name(0x00585730)="127.0.0.3", executable_name(0x00585750)="./mpichbug", pid=2734 shell%
Matching up the pid values shows that the MPIR_proctable[rank] does not match the rank returned to the program by MPI_Comm_rank() for some of the MPI processes. Here's the MPI rank to MPIR_proctable rank mapping: 0 => 0 1 => 3 2 => 1 3 => 4 4 => 2 5 => 5
Do you agree that this is an MPICH Hydra bug?
Any advice on how to create an MPICH Trac account so that I can report the bug?
Thanks, John D.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
