Re: [mpich-discuss] Bug in mpiexec -configfile
Thanks John. I can reproduce this error. I've created a ticket for this issue. http://trac.mpich.org/projects/mpich/ticket/1773 -- Pavan On 11/08/2012 02:13 PM US Central Time, John Fettig wrote:
When I run
mpiexec -configfile myConfigFile
the input taken from the lines of myConfigFile is truncated at 1024 characters. If the executable doesn't appear in the first 1024 characters, mpiexec will complain that you didn't specify an executable. I see this because I set -env LD_LIBRARY_PATH which in my case is quite large.
Here is the output of mpiexec -info
$ mpiexec -info HYDRA build details: Version: 1.5 Release Date: Mon Oct 8 14:00:48 CDT 2012 CC: icc -L/usr/lib64 -lscif CXX: icpc -L/usr/lib64 -lscif F77: ifort -L/usr/lib64 -lscif F90: ifort -L/usr/lib64 -lscif Configure options: '--disable-option-checking' '--prefix=/home/jfe/local' '--disable-romio' '--disable-mpe' 'CC=icc' 'CXX=icpc' 'F77=ifort' 'FC=ifort' 'LIBS=-lpthread -lscif ' 'LDFLAGS=-L/usr/lib64 ' '--with-device=ch3:nemesis:scif,tcp' '--cache-file=/dev/null' '--srcdir=.' 'CFLAGS= -O2' 'CPPFLAGS= -I/home/jfe/Downloads/mpich2-1.5/src/mpl/include -I/home/jfe/Downloads/mpich2-1.5/src/mpl/include -I/home/jfe/Downloads/mpich2-1.5/src/openpa/src -I/home/jfe/Downloads/mpich2-1.5/src/openpa/src' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs Checkpointing libraries available: Demux engines available: poll select
Regards, John
_______________________________________________ mpich-discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
