Re: [mpich-discuss] bind/listen race condition
Hi Steve, Thanks for the report. I was able to reproduce it on my laptop with the latest git revision. I've created a Github issue to track it. Hopefully it will be fixed soon. https://github.com/pmodels/mpich/issues/2665 Ken On 06/27/2017 02:11 PM, Steve Krueger wrote:
I'm using a rather old 1.4.1p1 version, but I checked the latest sources, and I believe the problem still exists.
When starting multiple MPICH jobs, and using an MPICH_PORT_RANGE, I occasionally see the error: HYDU_sock_listen (./utils/sock/sock.c:128): listen error (Address already in use)
I believe two processes are successfully bind()ing the same port in the range, but then the second listen() call returns the error.
The code in sock.c loops through the port range attempting to find a port to bind to, and once the bind() succeeds, it only call listen() once. I think the code should tolerate an EADDRINUSE error from listen() and retry a new port.
The problem is easier to reproduce if you add a sleep(10) between the bind() and listen(), and then run two mpi jobs with the same MPICH_PORT_RANGE.
sk
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
