Trying to work with the MPICH test suite, need a little help processing the results
Hey, So... I'm working with the MPICH test suite to check for bugs in some pre-release OFI changes I'm working on, but I could use a little help processing the resulting XML files. First - is there a schema file for the output XML files? (I know about TestResults.xsl but I'm hoping to generate some Excel pivot tables for my managers to view) Second - I figured out how to exclude individual tests by creating my own testlist files but when I do, the XML output loses information about what type of test is being run. For example, if my test list reads: # do the rma tests rma Then the output will have the form: <MPITEST> <NAME>sampletest</NAME> <ARGS></ARGS> <NP>2</NP> <WORKDIR>./rma</WORKDIR> <STATUS>pass</STATUS> <TIME>0.123456789</TIME> </MPITEST> But if my test list reads: # do rma/sampletest rma/sampletest then the output will be: <MPITEST> <NAME>sampletest</NAME> <ARGS></ARGS> <NP>2</NP> <WORKDIR>./</WORKDIR> <STATUS>pass</STATUS> <TIME>0.123456789</TIME> </MPITEST> This makes it a bit harder to quickly group error reports by category. Any suggestions for retaining the working directory in this case? Thanks in advance. --- Michael Heinz Fabric Software Engineer, Cornelis Networks External recipient
participants (1)
Heinz, Michael William
