Re: [mpich-discuss] Unexpected "Bad termination"
Every time the application (not MPICH) has an error, the same error message is shown. I'm going to go and delete that error message now since users keep thinking this is a problem in MPICH, while MPICH is only trying to be helpful and telling them that "this is not MPICH's fault. your application is broken." Maybe I should just say that in the error message. -- Pavan
On Jan 29, 2016, at 10:49 AM, Daniel Ibanez <[email protected]> wrote:
Hello all,
Sorry to intrude on someone else's question, but we also see this error message on our Linux cluster, with code that we're very confident is free of MPI bugs (has run on most of Mira, etc...).
The MPICH build being used was compiled on our workstations, and runs well on the workstations (up to the 16 ranks their CPUs handle). However, using that MPICH install on the cluster causes this for small (2-4) rank operations.
I'm saying this to suggest that it has to do with interactions of MPICH and the architecture/OS, maybe also with MPICH build configuration.
I'll try to come up with a reproducing test program today.
On Fri, Jan 29, 2016 at 11:42 AM, Halim Amer <[email protected]> wrote: Luiz,
You are experiencing a segmentation fault. We don't have enough information to pinpoint the source of the problem, however. We usually require a small piece of code that reproduces the bug to help debugging.
--Halim
www.mcs.anl.gov/~aamer
On 1/29/16 10:27 AM, Luiz Carlos da Costa Junior wrote: Dear all,
We have been using MPICH with our software and performing execution in Amazon AWS Linux servers for a long time. We use to have in production environment MPICH version 1.4.1p1 (which - I know - is very old), but it has been very very stable in the latest years. However, recently we have been facing a "Bad termination" problem once in a while, so we decided to investigate this issue. In principle, we don't have a apparent reason to believe that the problem lies on our code, since there was no changes that explain this behavior. The other point is that it occurs in a intermittent fashion, if we run the program again it doesn't happen, so it has been difficult to debug/trace the source of the problem.
Our first step, then, was to update the MPI version to the latest version 3.2. However, we faced the same problem (output below):
===================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 11 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================== [proxy:0:0@ip-10-137-129-86] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed [proxy:0:0@ip-10-137-129-86] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [mpiexec@ip-10-137-129-86] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting [mpiexec@ip-10-137-129-86] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@ip-10-137-129-86] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion [mpiexec@ip-10-137-129-86] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Do you have any clue about what might have been causing this problem? Any suggestion at this point would be highly appreciated.
Best regards, Luiz
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
