Hi Lorenzo, My understanding is that you must have ISO_Fortran_binding support in your Fortran compiler in order to use the mpi_f08 capabilities of MPICH. Currently, GFortran (as of 8.2) does not support ISO_Fortran_binding natively. However, you may try downloading and installing ISO_Fortran_binding from: https://github.com/sourceryinstitute/iso_fortran_binding. Currently, the tests make use of C VLAs, so if you compile with a C compiler other than GCC the tests may fail to build. However, the runtime *should* (AFAIK) still work, as I don't believe we used VLAs or any other (breaking) GNU extensions in the source itself. If you install ISO_Fortran_binding onto your default system search path before configuring MPICH, then I think MPICH will find it and enable the f08 module. I have no idea what is wrong with TotalView. Good luck! Zaak Izaak "Zaak" Beekman ------------------------------------------------------------------------------- HPC Scientist [email protected] ParaTools Inc. <http://www.paratools.com/> 1509 16th St, NW Washington, DC 20036 mobile: (917) 797-3239 ------------------------------------------------------------------------------- On Mon, Sep 17, 2018 at 9:25 AM <[email protected]> wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. mpi_f08 and Totalview (Lorenzo Zanon)
Message: 1 Date: Mon, 17 Sep 2018 15:25:45 +0200 From: Lorenzo Zanon <[email protected]> To: [email protected] Subject: [mpich-discuss] mpi_f08 and Totalview Message-ID: <[email protected]> Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hello,
After the mpich installation I have these two issues:
- I cannot use the module mpi_f08 in a Fortran program, only the old mpi module. The compilation error is:
Fatal Error: Can't open module file ?mpi_f08.mod? for reading at (1): No such file or directory compilation terminated.
- I cannot debug with Totalview. Totalview freezes when starting a debug session with "go" and a breakpoint, without error message. Maybe there was something wrong in my debug configuration options?
Attached are my c.txt and m.txt files.
Thanks for helping! Best, Lorenzo
-- ============================ Lorenzo Zanon
Institute of Applied Mechanics Continuum Mechanics and Mechanobiology University of Stuttgart
Pfaffenwaldring 5a 70569 Stuttgart Germany
[email protected] +49 (0)711 685 60 829 <+49%20711%2068560829> +49 (0)1577 2790439 <+49%201577%202790439> ============================
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Zaak Beekman
