Re: [mpich-discuss] Communication Error when installing MPICH on multi HOSTS.
It’s hard to tell, but this does indicate some problem with your communication setup. Did you verify your /etc/hosts like described on the FAQ page? — Pavan From: 维洛逐风 <[email protected]<mailto:[email protected]>> Reply-To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> Date: Tuesday, February 18, 2014 at 5:21 AM To: discuss <[email protected]<mailto:[email protected]>> Subject: [mpich-discuss] Communication Error when installing MPICH on multi HOSTS. HI. My environment: Two Vmware VMs with ubuntu-server12.04 OS, called mpimaster,mpislaver1 they both linked to a virtual network 10.0.0.1; they can ssh to each other without password; I have disabled the fire walls with "sudo ufw disable" I install mpich3.0.4 on a NFS servered by mpimaster. I installed mpich3.0.4 follow the "readme.txt", it has Communication problem when progresses from different host comunicate with each other. [cid:[email protected]] From picture above we can see it's ok to run "cpi" on both hosts separately. If you can't see the picture,plz see the shell's below. ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -n 4 ./examples/cpi Process 0 of 4 is on mpimaster Process 1 of 4 is on mpimaster Process 2 of 4 is on mpimaster Process 3 of 4 is on mpimaster pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.028108 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpimaster -n 4 ./examples/cpi Process 2 of 4 is on mpimaster Process 0 of 4 is on mpimaster Process 1 of 4 is on mpimaster Process 3 of 4 is on mpimaster pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.027234 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpislaver1 -n 4 ./examples/cpi Process 0 of 4 is on mpislaver1 pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.000093 Process 1 of 4 is on mpislaver1 Process 2 of 4 is on mpislaver1 Process 3 of 4 is on mpislaver1 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpimaster,mpislaver1 -n 4 ./examples/cpi Process 0 of 4 is on mpimaster Process 2 of 4 is on mpimaster Fatal error in PMPI_Reduce: A process has failed, error stack: PMPI_Reduce(1217)...............: MPI_Reduce(sbuf=0x7fff73a51ce8, rbuf=0x7fff73a51cf0, count=1, MPI_DOUBLE, MPI_SUM, root=0, MPI_COMM_WORLD) failed MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(779)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(144).......: MPIDI_CH3U_Recvq_FDU_or_AEP(667): Communication error with rank 1 MPIR_Reduce_intra(799)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(206).......: Failure during collective ================================================================================ = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ================================================================================ [proxy:0:1@mpislaver1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886) [proxy:0:1@mpislaver1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c [proxy:0:1@mpislaver1] main (./pm/pmiserv/pmip.c:206): demux engine error waitin [mpiexec@mpimaster] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_ [mpiexec@mpimaster] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wa [mpiexec@mpimaster] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:21 [mpiexec@mpimaster] main (./ui/mpich/mpiexec.c:331): process manager error waiti ailab@mpimaster:~/Downloads/mpich-3.0.4$ plz help,THX! ------------------ Jie-Jun Wu Department of Computer Science, Sun Yat-sen University, Guangzhou, P.R. China
participants (1)
Balaji, Pavan
