Re: [mpich-discuss] CUDA support with clang instead of nvcc
The configure in yaksa will set correct -ccbin option for nvcc to use the compiler set by CC. Reference https://github.com/pmodels/yaksa/blob/e4063c04b6ceeda7d863449a4e92124feb5b73... Ideally, it should use CXX rather than CC. But it currently works to compile the cu files in yaksa. -- Hui [https://opengraph.githubassets.com/23e05374cb64ce76ccf37f70c107678c6cd0fc7bb14a3965eaf36fced39609a5/pmodels/yaksa]<https://github.com/pmodels/yaksa/blob/e4063c04b6ceeda7d863449a4e92124feb5b739a/src/backend/cuda/subconfigure.m4#L65-L70> yaksa/subconfigure.m4 at e4063c04b6ceeda7d863449a4e92124feb5b739a · pmodels/yaksa<https://github.com/pmodels/yaksa/blob/e4063c04b6ceeda7d863449a4e92124feb5b739a/src/backend/cuda/subconfigure.m4#L65-L70> Yaksa: High-performance Noncontiguous Data Management - yaksa/subconfigure.m4 at e4063c04b6ceeda7d863449a4e92124feb5b739a · pmodels/yaksa github.com ________________________________ From: Raffenetti, Ken <[email protected]> Sent: Friday, April 15, 2022 3:02 PM To: [email protected] <[email protected]> Cc: Zhou, Hui <[email protected]> Subject: Re: [mpich-discuss] CUDA support with clang instead of nvcc The Yaksa configure is currently hardcoded to use `nvcc` for .cu files. We'll have to patch it to support alternatives, right? Ken On 4/15/22, 2:57 PM, "Zhou, Hui via discuss" <[email protected]> wrote: Yes, just set CC=clang and CXX=clang++. -- Hui Zhou ________________________________________ From: Sajid Ali via discuss <[email protected]> Sent: Friday, April 15, 2022 11:49 AM To: [email protected] <[email protected]> Cc: Sajid Ali <[email protected]> Subject: [mpich-discuss] CUDA support with clang instead of nvcc Hi MPICH-developers, Is it possible to compile MPICH with CUDA awareness, but with clang as the CUDA compiler? (i.e. use clang capable of targeting the nvptx backend to compiler cuda files instead of nvcc). Thank You, Sajid Ali (he/him) | Research Associate Scientific Computing Division Fermi National Accelerator Laboratory s-sajid-ali.github.io <http://s-sajid-ali.github.io>
participants (1)
Zhou, Hui
