Re: [mpich-discuss] Fatal error in PMPI_Reduce
Hi Pavan ~ Thanks for the reply. I did verify connectivity prior to trying the program. In this test case I have two systems, each with 16 cores (cv-hpcn1 and cv-hpcn2). ssh between the two systems appears to be working as far as I can tell: cv-hpcn1$ ssh cv-hpcn1 date Sat Jan 12 10:20:01 PST 2013 cv-hpcn1$ ssh cv-hpcn2 date Sat Jan 12 10:19:23 PST 2013 cv-hpcn1$ ssh cv-hpcn2 cv-hpcn2$ ssh cv-hpcn1 date Sat Jan 12 10:20:43 PST 2013 Here's the full test run of cxxcpi: cv-hpcn1$ /usr/local/apps/MPICH2/standalone/bin/mpirun -n 32 -f /usr/local/apps/hosts /usr/local/apps/cxxcpi Process 17 of 32 is on cv-hpcn2 Process 19 of 32 is on cv-hpcn2 Process 20 of 32 is on cv-hpcn2 Process 21 of 32 is on cv-hpcn2 Process 22 of 32 is on cv-hpcn2 Process 23 of 32 is on cv-hpcn2 Process 24 of 32 is on cv-hpcn2 Process 26 of 32 is on cv-hpcn2 Process 28 of 32 is on cv-hpcn2 Process 29 of 32 is on cv-hpcn2 Process 30 of 32 is on cv-hpcn2 Process 31 of 32 is on cv-hpcn2 Process 16 of 32 is on cv-hpcn2 Process 18 of 32 is on cv-hpcn2 Process 25 of 32 is on cv-hpcn2 Process 27 of 32 is on cv-hpcn2 Process 1 of 32 is on cv-hpcn1 Process 2 of 32 is on cv-hpcn1 Process 10 of 32 is on cv-hpcn1 Process 12 of 32 is on cv-hpcn1 Process 14 of 32 is on cv-hpcn1 Process 15 of 32 is on cv-hpcn1 Process 0 of 32 is on cv-hpcn1 Process 5 of 32 is on cv-hpcn1 Process 8 of 32 is on cv-hpcn1 Process 13 of 32 is on cv-hpcn1 Process 11 of 32 is on cv-hpcn1 Process 3 of 32 is on cv-hpcn1 Process 9 of 32 is on cv-hpcn1 Process 7 of 32 is on cv-hpcn1 Process 4 of 32 is on cv-hpcn1 Process 6 of 32 is on cv-hpcn1 Fatal error in PMPI_Reduce: A process has failed, error stack: PMPI_Reduce(1217)...............: MPI_Reduce(sbuf=0x7ffff0ab2320, rbuf=0x7ffff0ab2328, count=1, MPI_DOUBLE, MPI_SUM, root=0, MPI_COMM_WORLD) failed MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(779)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(144).......: MPIDI_CH3U_Recvq_FDU_or_AEP(612): Communication error with rank 16 MPIR_Reduce_intra(799)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(206).......: Failure during collective ============================================================================ ======= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ============================================================================ ======= [proxy:0:1@cv-hpcn2] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:1@cv-hpcn2] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [proxy:0:1@cv-hpcn2] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@cv-hpcn2] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:76): one of the processes terminated badly; aborting [mpiexec@cv-hpcn2] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@cv-hpcn2] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:217): launcher returned error waiting for completion [mpiexec@cv-hpcn2] main (./ui/mpich/mpiexec.c:330): process manager error waiting for completion Thanks for any advice. I've built many different versions of MPICH many times and this one has me scratching me head. I'm rebuilding everything identically on a pair of little VMs now to see if I can repeat the behavior outside of these systems. ~Mike C. -----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: Friday, January 11, 2013 9:20 PM To: Michael Colonno Cc: [email protected] Subject: Re: [mpich-discuss] Fatal error in PMPI_Reduce On 01/11/2013 09:18 PM US Central Time, Michael Colonno wrote:
The first output below is from cxxcpi; I can also run cpi is it's helpful.
Ah, sorry, I didn't realize you were in fact running one of the test programs distributed in MPICH. Based on the error, some of the nodes are not able to connect to each other based on the hostnames they are publishing. Did you try the solutions listed on the FAQ: <http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_My_MPI_ program_aborts_with_an_error_saying_it_cannot_communicate_with_other_process es> http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_My_MPI_p rogram_aborts_with_an_error_saying_it_cannot_communicate_with_other_processe s -- Pavan -- Pavan Balaji <http://www.mcs.anl.gov/~balaji> http://www.mcs.anl.gov/~balaji
participants (1)
Michael Colonno
