Re: [mpich-discuss] VA_ARGS support
3.0.4 works fine, this is a new problem. Thanks, Jim On Feb 25, 2014, at 11:23 AM, Bland, Wesley B. wrote:
Just to confirm, this is a new problem with 3.1? It didn’t appear in 3.0.4 (or any of the rc’s if you used any of them)?
Thanks, Wesley
On Feb 25, 2014, at 2:17 PM, James Long <[email protected]> wrote:
On Feb 25, 2014, at 11:07 AM, Bland, Wesley B. wrote:
Can you provide your config.log?
On Feb 25, 2014, at 2:06 PM, James Long <[email protected]> wrote:
Under debian 7.4, trying to compile mpich-3.1 with Portland Group 13.6, or 14.2, same error results in both cases:
make[3]: Entering directory `/home/user/mpich-3.1/src/pm/hydra' CC utils/alloc/alloc.lo PGC/x86-64 Linux 13.6-0 Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved. Copyright 2000-2013, STMicroelectronics, Inc. All Rights Reserved. PGC-F-0249-#error -- "hydra requires VA_ARGS support" (./include/hydra.h: 79) PGC/x86-64 Linux 13.6-0: compilation aborted
environment variables used: $ unset F90 $ export CC=pgcc $ export FC=pgf90 $ export CXX=pgCC $ export CPPFLAGS="-DNDEBUG -DpgiFortran" $ export CFLAGS="-O2 -V" $ export FFLAGS="-O2 -w -V"
Jim --
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% James Long International Arctic Research Center University of Alaska Fairbanks jlong|at|alaska.edu (907) 474-2440 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% James Long International Arctic Research Center University of Alaska Fairbanks jlong|at|alaska.edu (907) 474-2440 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
participants (1)
James Long
