Re: [mpich-discuss] Fwd: mpich-3.2 using cygwin
Cygwin isn't Windows. Cygwin is a very good approximation to Linux that happens to run on top of Windows. Jeff On Mon, Feb 1, 2016 at 1:47 PM, Halim Amer <[email protected]> wrote:
We don't support Windows anymore. For more information, refer to https://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_Why_can... .
---Halim
www.mcs.anl.gov/~aamer
On 2/1/16 3:26 PM, Bhanu Hariharan wrote:
Hello,
I am trying to build the mpich-3.2 libs on a Windows 64 bit Vista.
I am using cygwin and I am following the configure and build instructions on http://www.mpich.org/static/downloads/3.2/mpich-3.2-installguide.pdf
On launching the configure command, I first ran into OpenPA errors, so just to get around it I renamed openpa folder in src to ##openpa
Then I ran into some fortran errors - I have ifort compiler. "Could not determine a way to link a Fortran test program!"
I am sending you c.txt and config.log as was suggested in the .pdf. Could anyone help me understand why I might be getting the error and a way out.
Thanks in advance, Regards, Bhanu
PS: Separate question: I was able to find .msi for older versions of mpich2 but not anymore. Can I download .msi for latest mpich2 versions?
------------------------------------------------------------------------ *DISCLAIMER*: This e-mail and any files transmitted with it ("Message") is intended only for the use of the recipient(s) named above and may contain confidential information. You are hereby notified that the taking of any action in reliance upon, or any review, retransmission, dissemination, distribution, printing or copying of this Message or any part thereof by anyone other than the intended recipient(s) is strictly prohibited. If you have received this Message in error, you should delete this Message immediately and advise the sender by return e-mail. Opinions, conclusions and other information in this Message that do not relate to the official business of PETROTEL or its affiliated Companies shall be understood as neither given nor endorsed by PETROTEL or any of its affiliated companies.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
