Re: [mpich-discuss] Deadlock when using MPICH 3.1.1 and per-object critical sections on BG/Q
Hi Michael, Thanks. I created a ticket (#2132) on trac.mpich.org to track the problem. Regards, --Halim On 2014年06月26日 17:41, Michael Blocksome wrote:
Halim,
This problem sounds similar to another issue we are debugging related to cancel and multiple endpoints in per-object locking mode. I'll try a few things and post status.
Michael Blocksome Parallel Environment MPI Middleware Team Lead, TCEM POWER, x86, and Blue Gene HPC Messaging [email protected]
From: Halim <[email protected]> To: [email protected], Date: 06/26/2014 02:31 PM Subject: [mpich-discuss] Deadlock when using MPICH 3.1.1 and per-object critical sections on BG/Q Sent by: [email protected]
I have a specific issue that arises with MPICH (I use 3.1.1 built with gcc) + MPI_THREAD_MULTIPLE + per-object critical sections on BG/Q.
A deadlock happens in the attached hybrid MPI+OpenMP example code with 2 processes and more than one thread per process.
Debugging shows that one process is stuck in MPI_Allreduce while the other is blocked in MPI_Finalize.
A similar communication pattern happens in my application, but in this case both processes are stuck in MPI_Allreduce.
Note that the problem disappears when removing MPI_Allreduce, or avoiding request cancellation (cancel+wait+test_cancelled). Both Allreduce and cancellation operations can be avoided in this test while ensuring a correct result. But in my application, both operations are necessary.
In addition, using a global critical section (default) results in a correct execution.
My configure line is as follows:
./configure --prefix=/home/aamer/usr --host=powerpc64-bgq-linux --with-device=pamid --with-file-system=gpfs:BGQ --with-file-system=bg+bglockless --with-atomic-primitives --enable-handle-allocation=tls --enable-refcount=lock-free -disable-predefined-refcount --disable-error-checking --without-timing --without-mpit-pvars --enable-fast=O3,ndebug --enable-thread-cs=per-object
I appreciate any advice to solve this issue?
Regards, --Halim [attachment "allred_cancel.c" deleted by Michael Blocksome/Rochester/IBM] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Halim
