Re: [mpich-discuss] Weird thing -- MPICH2 on domain
Jayesh, I did not run the program across machines. My laptop has 8 cores, and my desktop has 4 cores. I ran the program individually on each PC. Here is the command line: mpiexec -user 0 -np 4 test.exe What the program does is: Using the main processor (imrank = 0) to create a file and write records; after that, all processors will access this file and read the records multiple times (Open the file in read only --> Read records --> Close file --> Reopen --> And so on). Thanks. From: Jayesh Krishna <[email protected]> To: [email protected], Cc: [email protected] Date: 01/29/2013 10:24 AM Subject: Re: [mpich-discuss] Weird thing -- MPICH2 on domain Hi, Is there any communication (MPI) between the laptop and the desktop? MPICH2 currently does not support running MPI programs across 32-bit and 64-bit machines. How are you running your program (The complete mpiexec command and the output. Please copy-paste it from the command window)? Regards, Jayesh ----- Original Message ----- From: "Qiguo Jing" <[email protected]> To: [email protected] Sent: Friday, January 25, 2013 5:16:58 PM Subject: [mpich-discuss] Weird thing -- MPICH2 on domain All, I have been encountering a weird thing, which draw me crazy. I hope someone here can help me. I have two computers, a laptop (Windows 7 64 bit) and a desktop (Window 7 32 bit). Both are in company domain, and I use the some information to login. So the MPICH2 registration information are the same for both computers. I developed a parallel FORTRAN program using my laptop. 1. If I connect the internet cable on laptop. --> Program works. Results are good. 2. If I disconnect the internet cable on laptop. --> Program fails, saying Program Exception - access violation 3. If I connect the internet cable on Desktop. --> Program runs and finishes, but the results are wrong. Slave processors and master processor do not communicate, so that results on slave processor can not be passed to main processor. 4. If I disconnect the internet cable on Desktop. -> Program works. Results are good. Can someone help? Thanks. _________________________________________________________________________ The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you Received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _________________________________________________________________________ The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you Received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________
participants (1)
Qiguo Jing
