Re: [mpich-discuss] Fault tolerance MPICH2 hydra vs MPICH3.0.4 hydra
Hi Anatoly, I think the problem may be the way that you're aborting. MPICH catches the system abort call and kills the entire application when it's called. Instead, I suggest using MPI_Abort(MPI_COMM_WORLD, 1); That's what I use in my tests and it works fine. It also seemed to work for your code when I tried. I'll attach my modified version of your code. I switched it to C since I happened to have C++ support disabled on my local install, but that shouldn't change anything. Thanks, Wesley On Sun, May 18, 2014 at 5:18 AM, Anatoly G <[email protected]> wrote:
Dear MPICH2, Can you please help me with understanding Fault Tolerance in MPICH3.0.4 I have a simple MPI program: Master calls MPI_Irecv + MPI_Wait in loop. Single slave: calls MPI_Send x 5 times, then calls abort.
When I execute program with MPICH2 hydra I get multiple times Master process prints about fail in slave. In MPICH3 hydra I get a single message about fail of slave and then Master process enters to endless wait for next Irecv completion. In both cases I compiled program with MPICH3.0.4
In other words, with MPICH2 hydra each Irecv completes (even if slave died before execution of Irecv) but in MPICH3 hydra not. Causes MPI_Irecvendless wait.
If I compile same program with MPICH2 and use MPICH2 hydra, I get the same result as compiling with MPICH3.0.4 and running with MPICH2 hydra.
Execution command: mpiexec.hydra -genvall -disable-auto-cleanup -f MpiConfigMachines1.txt-launcher= rsh -n 2 mpi_irecv_ft_simple
Both hydra's configured with: $ ./configure --prefix=/space/local/mpich-3.0.4/ --enable-error-checking=runtime --enable-g=dbg CFLAGS=-fPIC CXXFLAGS=-fPIC FFLAGS=-fpic --enable-threads=runtime --enable-totalview --enable-static --disable-f77 --disable-fc --no-recursion
$ ./configure --prefix=/space/local/mpich2-1.5b2/ --enable-error-checking=runtime --enable-g=dbg CFLAGS=-fPIC CXXFLAGS=-fPIC FFLAGS=-fpic --enable-threads=runtime --enable-totalview --enable-static --disable-f77 --disable-fc
Can you advice please?
Regards, Anatoly.
participants (1)
Wesley Bland
