Re: [mpich-discuss] From file reading to memory sharing
Hi, I'm gessing the cause of the performance issue is the large number of small requests, because when I read the full 7GB using a single process issuing one single MPI_File_read, it gets much better. Matthieu ________________________________________ From: Wei-keng Liao [[email protected]] Sent: Wednesday, August 12, 2015 11:56 AM To: [email protected] Subject: Re: [mpich-discuss] From file reading to memory sharing Hi, Matthieu If you have "a series of subdomains (blocks) to load from the file", one way to get a better I/O performance is to concatenate the filetypes into a single one and then use only one MPI_File_set_view and one MPI_File_read_all to read the data. FYI. This request aggregation strategy is also used in PnetCDF. Wei-keng On Aug 12, 2015, at 11:27 AM, Dorier, Matthieu wrote:
I'm trying to refactor an MPI code using MPI one-sided communications.
The initial version of the code reads its data from a file containing a 3D array of floats. Each process has a series of subdomains (blocks) to load from the file, so they all open the file and then issue a series of MPI_File_set_view and MPI_File_read. The type passed to MPI_File_set_view is constructed using MPI_Type_create_subarray to match the block that needs to be loaded.
This code performs very poorly even at small scale: the file is 7GB but the blocks are a few hundreds of bytes, and each process has many blocks to load.
Instead, I would like to have process rank 0 load the entire file, then expose it over RMA. I'm not familiar at all with MPI one-sided operations, since I never used them before, but I guess there should be a simple way to reuse the subarray datatype of my MPI_File_set_view and use it in the context of an MPI_Get. I'm just not sure what the arguments of this MPI_Get would be. My guess is: origin_count would be the number of floats in a single block, origin_datatype would be MPI_FLOAT, target_rank = 0, target_disp = 0, target_count = 1, target_datatype = my subarray datatype. Would that be correct?
Matthieu _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Dorier, Matthieu
