Re: [mpich-discuss] Different architectures
Hi Peter, Yes -- you will have to install a 32 bit build of MPICH on all machines in your cluster, and you will also have to ensure that your application is built as a 32-bit binary on all machines. The problem is that 32/64 bit nodes won't agree on the sizes of basic datatypes (integer, address, etc), which complicates communication and can have a performance impact. Technically, the MPI standard supports such heterogeneous system configurations, but most MPI implementations (including MPICH) do not. Best, ~Jim. On 12/9/12 2:55 PM, Peter Kroon wrote:
Are you suggestion that I should install a 32b version on all machines because 32b can't *talk* to 64b?
2012/12/9 Jeff Hammond <[email protected] <mailto:[email protected]>>
It appears you're trying to use the 64b library (ELFCLASS64...) on the 32b master. In any case, I don't believe MPICH works in the heterogeneous case. In theory, you should be able to use a 32b library across both machines though.
Jeff
On Sun, Dec 9, 2012 at 1:40 PM, Peter Kroon <[email protected] <mailto:[email protected]>> wrote: > Hello, > > I've installed mpich2 on ubuntu i386(master) via > https://help.ubuntu.com/community/MpichCluster > I have another machine amd64(slave). > > When i run my script on master I get an error: error while loading shared > libraries: linbmpich.so.3: wrong ELF CLASS: ELFCLASS64 > > Is mpich compatible with different architectures? If so what's the easiest > way for me to get rid of my error? > > Also note that I need this to work with x86-64 as well. > > Best, > Peter > > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] <mailto:[email protected]> / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jim Dinan
