Re: [mpich-discuss] turning off MPI abort messages
https://trac.mpich.org/projects/mpich/ticket/2038 has the patches. Jeff On Fri, Feb 21, 2014 at 3:47 PM, Jeff Hammond <[email protected]> wrote:
Barry:
Can you tolerate the following workaround for Hydra's error cleanup or do you need it to be internal? I presume you know enough bash to generalize a.sh appropriately.
alcfwl181:build jhammond$ cat a.sh #!/bin/sh $1 true alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 0 ./a.sh ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 1 ./a.sh ./a.out
alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 1 ./a.out
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61123 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 0 ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61126 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
On Fri, Feb 21, 2014 at 3:10 PM, Jeff Hammond <[email protected]> wrote:
Barry:
Would the following behavior be acceptable to you? I have only made the changes in MPI but am looking at the process manager now.
Jeff
# Without the process manager
alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=0 alcfwl181:build jhammond$ ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=1 alcfwl181:build jhammond$ ./a.out
alcfwl181:build jhammond$ unset MPIR_CVAR_SUPPRESS_ABORT_MESSAGE alcfwl181:build jhammond$ ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
# With the process manager
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61023 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 1 ./a.out
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61026 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== alcfwl181:build jhammond$ mpiexec -n 1 ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61032 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
On Thu, Feb 20, 2014 at 11:33 AM, Barry Smith <[email protected]> wrote:
Is there any way to turn off MPICH (and others) printing messages about MPI_Abort? We have already prepared and presented useful error messages to the user about the situation and would like to avoid having these additional messages printed (that often make the situation look worse than it is)
Thanks
Barry
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0 [cli_0]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
==================================================================mailto:[email protected]================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 56 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
