Re: [mpich-discuss] MPICH 3.3.2 Unable to Build on macOS 10.15
We identified this as an Intel compiler issue and added a workaround in https://github.com/pmodels/mpich/commit/59fd76de45bb4c5bfeff08883c4a37990522... to address it, but your report indicates it is still an issue. Unfortunately I do not have access to Intel compilers for macOS at the moment to test another fix. You can disable thread-local storage entirely in order to build with the configure option below. Note this may have negative performance implications for multi-threaded applications. ./configure pac_cv_tls=none [...] Ken On 1/27/20 3:48 PM, Songchen Tan via discuss wrote:
Hi Ken,
No problem, it is attached.
By the way, I also tried again on macOS 10.14, it failed due to the same reason, so it is unlikely that the problem is related to macOS 10.15.
Sincerely yours, Songchen
Songchen Tan 10292504 College of Chemistry, University of California, Berkeley 97420, U. S. A. Email: [email protected] Cell: (+86)13501382788 在 2020年1月28日 +0800 03:57,Raffenetti, Kenneth J. via discuss <[email protected]>,写道:
Can you also send along src/mpl/config.log from your build directory?
Ken
On 1/27/20 11:57 AM, Songchen Tan via discuss wrote:
Dear Developers,
I am Songchen Tan at UC Berkeley, recently I am trying to use MPICH on macOS 10.15. Though binaries via homebrew is available, I would like to build from source in order to configure it with Intel compilers (icc, icpc and ifort).
To reproduce the problem:
1. Download the source in ~/Applications/; 2. Unzip with `tar -xvzf mpich-3.3.2.tar.gz`, then `cd mpich-3.3.2`; 3. Run `./configure --prefix=/usr/local/Cellar/mpich/3.3.2 CC=icc CXX=icpc F77=ifort FC=ifort 2>&1 | tee c.txt`; 4. Build with `make VERBOSE=1 2>&1 | tee m.txt`. 5. Then I am noticed: `Undefined symbols for architecture x86_64: “__ZTHMPIR_Per_thread”`.
The generated `c.txt` and `m.txt` is attached. Thank you so much for your help.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
