Re: [mpich-discuss] mpich-3.2 34
Hi Ken I can send you the Makefile and output but the code has run successfully using various other flavours of mpi and compilers - mpich2, openmpi, intel mpi, gfortran and ifort etc. The example program pi3f90.f90 produces a similar error: wpj@kelvin:f90 20 mpif90 pi3f90.f90 Encountered 0 errors, 0 warnings in file pi3f90.f90. /usr/bin/ld: a.out: hidden symbol `lstat64' in /usr/lib64/libc_nonshared.a(lstat64.oS) is referenced by DSO /usr/bin/ld: final link failed: Nonrepresentable section on output Regards Bill Professor W P Jones Department of Mechanical Engineering Imperial College London Exhibition Road London SW7 2AZ Tel: +44 (0)20 7594 7037/7033 Mobile +44 (0)776 495 9702 Fax: +44 (0)20 7594 5702 E-mail: [email protected] web site: http://www.imperial.ac.uk/me On 05/01/16 18:08, Kenneth Raffenetti wrote:
Do you have a make log from the application you are trying to build that you can share?
Separately, did the example cpi application build successfully at the end of the MPICH build?
Ken
On 01/05/2016 02:44 AM, Professor W P Jones wrote:
Hi
I have successfully compiled and installed the version suggested. However when I attempt to to use make to compile and link it fails on the link step with the message:
/usr/bin/ld: boffin: hidden symbol `lstat64' in /usr/lib64/libc_nonshared.a(lstat64.oS) is referenced by DSO /usr/bin/ld: final link failed: Nonrepresentable section on output make: [boffin] Error 1 (ignored) mv: cannot stat `./x86_64/boffin': No such file or directory make: *** [boffin] Error 1
The log files generated in the compiled and install are attached and the output from mpiexec -info is:
HYDRA build details: Version: 3.2 Release Date: Mon Jan 4 00:00:40 CST 2016 CC: icc CXX: icpc F77: lf95 F90: lf95 Configure options: '--disable-option-checking' '--prefix=/opt/mpich' '--enable-fortran=all' 'FC=lf95' 'F77=lf95' '--cache-file=/dev/null' '--srcdir=.' 'CC=icc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS=-lpthread ' 'CPPFLAGS= -I/usr/local/src/mpich-master-v3.2-42-g67631a5c0e9e/src/mpl/include -I/usr/local/src/mpich-master-v3.2-42-g67631a5c0e9e/src/mpl/include -I/usr/local/src/mpich-master-v3.2-42-g67631a5c0e9e/src/openpa/src -I/usr/local/src/mpich-master-v3.2-42-g67631a5c0e9e/src/openpa/src -D_REENTRANT -I/usr/local/src/mpich-master-v3.2-42-g67631a5c0e9e/src/mpi/romio/include'
'MPLLIBNAME=mpl' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: Demux engines available: poll select
Regards Bill
On 04/01/16 15:55, Kenneth Raffenetti wrote:
Can you try the latest nightly tarball on the MPICH website? I committed a patch last night that I believe addresses the issue. I don't have a system with the lf95 compiler to test, so I just went from the documentation.
Ken
On 12/27/2015 07:49 PM, Professor W P Jones wrote:
Hi Pavan
Here are all the existing log files.
Regards Bill
On 28/12/15 00:40, Balaji, Pavan wrote:
Could you send us the log files listed in the README?
http://git.mpich.org/mpich.git/blob/HEAD:/README.vin#l235
-- Pavan
On Dec 27, 2015, at 5:34 AM, Professor W P Jones <[email protected]> wrote:
Hi
I am trying to build MPICH-3.2 34 using Lahey/Fujitsu Linux64 Fortran Express Release L8.10b and I obtain the following error:
checking for Fortran 90 module output directory flag... configure: error: FCMODOUTFLAG could not be determined but is critical for the current Fortran build system
Please can you advise how this can be fixed?
Many thanks Bill Jones
-- Professor W P Jones Department of Mechanical Engineering Imperial College London Exhibition Road London SW7 2AZ Tel: +44 (0)20 7594 7037/7033 Mobile +44 (0)776 495 9702 Fax: +44 (0)20 7594 5702 E-mail: [email protected] web site: http://www.imperial.ac.uk/me
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Professor W P Jones
