Re: [mpich-discuss] single node mpiio
On 01/12/2016 11:36 AM, Jaln wrote:
Hi, I'm running hdft with mpiio on a single compute node (32 cores), 10 OSTs, the file system is lustre v2.5. I submit the job with 3 processes, they are writing to a shared file, which is about 3GBs, and each process writes 1/3 of the file, for example, The array is a 4D double array, 3*32*1024*128, then each process writes 32*1024*128 to the file, which is contiguous.
I observed some wired performance number, I tried both independent I/O and collective IO. In the case of independent I/O, each rank seems to block each other and finish writing one after another. But in collective I/O, all three ranks reports same I/O cost, I think this is because there is only one aggregator. My question is, in the case of independent I/O, are the I/Os blocking when accessing the file? If not blocking, can I expect linear speedup on a single node by increasing number of processes?
There is a lot going on under the hood in collective mode. Let's start with independent mode. Here's my mental model of what's going on: - Your 3 process application issues 3 lustre writes. - One of those will win the race to the file system, acquire a whole-file lock, and begin to write. - Now the request from the 2nd place process arrives. Lustre will revoke the whole-file lock and issue a lock for the beginning of the request to the end of the file. - When the last process arrives, Lustre will revoke locks yet again, and issue a lock from the beginning of the request to the end of the file. So yep, there is indeed a lot of blocking going on. It's not a formal queue, more of a side effect of waiting for the Lustre MDS to issue the required locks. In collective I/O (which I'll assume is a relatively recent ROMIO implementation), one of your three mpi processes will be the aggregator. You seem to know about two-phase collective I/O so I will make the rest of the explanation brief. Yes, that aggregator will receive data from the other proceses and issue all I/O. The other processes will wait until the aggregator finishes, which is why you see all processes reporting the same run time for I/O. You are unlikely to get speedup from a single node for two main reasons: There are the aforementioned lock contention issues. There is a single link from that node to the 10 Lustre OSTs. In fact, due to the lock revocation activity I described above, you are likely to see a massive performance crash when you involve a second node. Then, as you add more nodes, you will finally light up enough network links to see a speedup. ==rob
Best, Jialin Lawrence Berkeley Lab
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rob Latham
