Re: [mpich-discuss] hydra, stdin close(), and SLURM
Hi Aaron, I've committed it to mpich/master: http://git.mpich.org/mpich.git/commitdiff/6b41775b2056ff18b3c28aab71764e3590... Thanks for the contribution. This should be in tonight's nightlies: http://www.mpich.org/static/downloads/nightly/master/mpich/ ... and in the upcoming mpich-3.2rc1 release. -- Pavan On 7/27/15, 1:40 PM, "Balaji, Pavan" <[email protected]> wrote:
Hi Aaron,
Please send the patch to me directly.
General guidelines as to the kind of patches we ask for:
https://wiki.mpich.org/mpich/index.php/Version_Control_Systems_101
You can ignore the git workflow related text, which is for our internal testing. I'll take care of that for you.
-- Pavan
On 7/27/15, 1:36 PM, "Aaron Knister" <[email protected]> wrote:
Hi Pavan,
I see your reply in the archives but it didn't make it to my inbox so I'm replying to my post. I don't disagree without you about the error being in the SLURM code, but I'm not sure how one would prevent this reliably. SLURM has no expectation that an external library will open something at file descriptor 0 before it reaches the point in the code where it's ready to poll for stdin. Do you have any suggestions?
It's been a long while since I've done a git e-mail patch so it might take me a bit to figure out. Should I send the patch to the list or to you directly?
Thanks!
-Aaron
On 7/25/15 10:26 PM, Aaron Knister wrote:
I sent this off to the mvapich list yesterday and it was suggested I raise it here since this is the upstream project:
This is a bit of a cross post from a thread I started on the slurm dev list: http://article.gmane.org/gmane.comp.distributed.slurm.devel/8176
I'd like to get feedback on the idea that "--input none" be passed to srun when using the SLURM hydra bootstrap mechanism. I figured it would be inserted somewhere around here http://trac.mpich.org/projects/mpich/browser/src/pm/hydra/tools/bootstrap/ex....
Without this argument I'm getting spurious job aborts and confusing errors. The gist of it is mpiexec.hydra closes stdin before it exec's srun. srun then (possibly via the munge libraries) calls some function that does a look up via nss. We use sssd for AAA so libnss_sssd will handle this request. Part of the caching mechanism sssd uses will cause the library to open() the cache file. The lowest fd available is 0 so the cache file is opened on fd 0. srun then believes it's got stdin attached and it causes the issues outlined in the slurm dev post. I think passing "--input none" is the right thing to do here since hydra has in fact closed stdin to srun. I tested this via the HYDRA_LAUNCHER_EXTRA_ARGS environment variable and it does resolve the errors I described.
Thanks! -Aaron
-- Aaron Knister NASA Center for Climate Simulation (Code 606.2) Goddard Space Flight Center (301) 286-2776
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
