--Junchao Zhang On Wed, Nov 26, 2014 at 4: 25 PM, Amin Hassani <[email protected]> wrote:
I disabled the whole firewall in those machines but, still get the same problem. connection refuse. I run the program in another set of totally different machines that we have, but still same problem. Any other thought where can be the problem?
Thanks.
Amin Hassani, CIS department at UAB, Birmingham, AL, USA.
On Wed, Nov 26, 2014 at 9: 25 AM, Kenneth Raffenetti <[email protected]=
wrote:
The connection refused makes me think a firewall is getting in the way. Is TCP communication limited to specific ports on the cluster? If so, yo= u can use this envvar to enforce a range of ports in MPICH.
MPIR_CVAR_CH3_PORT_RANGE Description: The MPIR_CVAR_CH3_PORT_RANGE environment variable allow= s you to specify the range of TCP ports to be used by the process manager = and the MPICH library. The format of this variable is <low>: <high>. To spec= ify any available port, use 0: 0. Default: {0,0}
On 11/25/2014 11: 50 PM, Amin Hassani wrote:
Tried with the new configure too. same problem: (
$ mpirun -hostfile hosts-hydra -np 2 test_dup Fatal error in MPI_Send: Unknown error class, error stack: MPI_Send(174)..............: MPI_Send(buf=3D0x7fffd90c76c8, count=3D1, MPI_INT, dest=3D1, tag=3D0, MPI_COMM_WORLD) failed MPID_nem_tcp_connpoll(1832): Communication error with rank 1: Connectio= n refused
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES =3D PID 5459 RUNNING AT oakmnt-0-a =3D EXIT CODE: 1 =3D CLEANING UP REMAINING PROCESSES =3D YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D [proxy: 0:1@oakmnt-0-b] HYD_pmcd_pmip_control_cmd_cb (../../../../src/pm/hydra/pm/pmiserv/pmip_cb.c: 885): assert (!closed) failed [proxy: 0:1@oakmnt-0-b] HYDT_dmxu_poll_wait_for_event (../../../../src/pm/hydra/tools/demux/demux_poll.c: 76): callback returned error status [proxy: 0:1@oakmnt-0-b] main (../../../../src/pm/hydra/pm/pmiserv/pmip.c: 206): demux engine error waiting for event [mpiexec@oakmnt-0-a] HYDT_bscu_wait_for_completion (../../../../src/pm/hydra/tools/bootstrap/utils/bscu_wait.c: 76): one of the processes terminated badly; aborting [mpiexec@oakmnt-0-a] HYDT_bsci_wait_for_completion (../../../../src/pm/hydra/tools/bootstrap/src/bsci_wait.c: 23): launcher returned error waiting for completion [mpiexec@oakmnt-0-a] HYD_pmci_wait_for_completion (../../../../src/pm/hydra/pm/pmiserv/pmiserv_pmci.c: 218): launcher returned error waiting for completion [mpiexec@oakmnt-0-a] main (../../../../src/pm/hydra/ui/mpich/mpiexec.c: 344): process manager erro= r waiting for completion
On Tue, Nov 25, 2014 at 11: 44 PM, Lu, Huiwei <[email protected] <mailto: [email protected]>> wrote:
So the error only happens when there is communication.
It may be caused by IB as your guessed before. Could you try to reconfigure MPICH using "./configure --with-device=3Dch3: nemesis:tc= p=E2=80=9D and try again?
=E2=80=94 Huiwei
> On Nov 25, 2014, at 11: 23 PM, Amin Hassani <[email protected] <mailto: [email protected]>> wrote: > > Yes it works. > output: > > $ mpirun -hostfile hosts-hydra -np 2 test > rank 1 > rank 0 > > > Amin Hassani, > CIS department at UAB, > Birmingham, AL, USA. > > On Tue, Nov 25, 2014 at 11: 20 PM, Lu, Huiwei <[email protected] <mailto: [email protected]>> wrote: > Could you try to run the following simple code to see if it work= s? > > #include <mpi.h> > #include <stdio.h> > int main(int argc, char** argv) > { > int rank, size; > MPI_Init(&argc, &argv); > MPI_Comm_rank(MPI_COMM_WORLD, &rank); > printf("rank %d\n", rank); > MPI_Finalize(); > return 0; > } > > =E2=80=94 > Huiwei > > > On Nov 25, 2014, at 11: 11 PM, Amin Hassani <[email protected] <mailto: [email protected]>> wrote: > > > > No, I checked. Also I always install my MPI's in /nethome/students/ahassani/usr/mpi. I never install them in /nethome/students/ahassani/usr. So MPI files will never get there. Even if put the /usr/mpi/bin in front of /usr/bin, it won't affect anything. There has never been any mpi installed in /usr/bin. > > > > Thank you. > > _______________________________________________ > > discuss mailing list [email protected] <mailto: [email protected]> > > To manage subscription options or unsubscribe: > > https: //lists.mpich.org/mailman/listinfo/discuss > > _______________________________________________ > discuss mailing list [email protected] <mailto: [email protected]=
> To manage subscription options or unsubscribe: > https: //lists.mpich.org/mailman/listinfo/discuss > > _______________________________________________ > discuss mailing list [email protected] <mailto: [email protected]=
_______________________________________________ discuss mailing list [email protected] <mailto: [email protected]> To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss
--001a11c108e02e57a30508cb605e Content-Type: text/html; charset="UTF-8" Content-Transfer-Encoding: quoted-printable <meta http-equiv=3D"Content-Type" content=3D"text/html; charset=3Dutf-8"><d= iv dir=3D"ltr"><div>I have no idea. You may try to trace all events as said= at <a href=3D"http: //wiki.mpich.org/mpich/index.php/Debug_Event_Logging">h= ttp: //wiki.mpich.org/mpich/index.php/Debug_Event_Logging</a></div><div>From= the trace log, one may find out something abnormal. </div></div=
<div class=3D"gmail_extra"><br clear=3D"all"><div><div class=3D"gmail_sign= ature"><div dir=3D"ltr">--Junchao Zhang</div></div></div> <br><div class=3D"gmail_quote">On Wed, Nov 26, 2014 at 4: 25 PM, Amin Hassan= i <span dir=3D"ltr"><<a href=3D"mailto: [email protected]" target=3D"_= blank">[email protected]</a>></span> wrote: <br><blockquote class=3D"g= mail_quote" style=3D"margin: 0 0 0 .8ex;border-left:1px #ccc solid;padding-l= eft: 1ex"><div dir=3D"ltr"><div class=3D"gmail_default" style=3D"font-family= : tahoma,sans-serif;font-size:small">I disabled the whole firewall in those = machines but, still get the same problem. connection refuse.</div><div clas= s=3D"gmail_default" style=3D"font-family: tahoma,sans-serif;font-size:small"= I run the program in another set of totally different machines that we hav= e, but still same problem.</div><div class=3D"gmail_default" style=3D"font-= family: tahoma,sans-serif;font-size:small">Any other thought where can be th= e problem?</div><div class=3D"gmail_default" style=3D"font-family: tahoma,sa= ns-serif;font-size: small"><br></div><div class=3D"gmail_default" style=3D"f= ont-family: tahoma,sans-serif;font-size:small">Thanks.</div></div><div class= =3D"gmail_extra"><span class=3D""><br clear=3D"all"><div><div><div dir=3D"l= tr">Amin Hassani,<br>CIS department at UAB,<br> Birmingham, AL, USA.</div></div></div> <br></span><div><div class=3D"h5"><div class=3D"gmail_quote">On Wed, Nov 26= , 2014 at 9: 25 AM, Kenneth Raffenetti <span dir=3D"ltr"><<a href=3D"mail= to: [email protected]" target=3D"_blank">[email protected]</a>></sp= an> wrote: <br><blockquote class=3D"gmail_quote" style=3D"margin:0 0 0 .8ex;= border-left: 1px #ccc solid;padding-left:1ex">The connection refused makes m= e think a firewall is getting in the way. Is TCP communication limited to s= pecific ports on the cluster? If so, you can use this envvar to enforce a r= ange of ports in MPICH.<br> <br> MPIR_CVAR_CH3_PORT_RANGE<br> Description: The MPIR_CVAR_CH3_PORT_RANGE environment variabl= e allows you to specify the range of TCP ports to be used by the process ma= nager and the MPICH library. The format of this variable is <low>: <= ;high>. To specify any available port, use 0: 0.<br> Default: {0,0}<div><div><br> <br> On 11/25/2014 11: 50 PM, Amin Hassani wrote:<br> </div></div><blockquote class=3D"gmail_quote" style=3D"margin: 0 0 0 .8ex;bo= rder-left: 1px #ccc solid;padding-left:1ex"><div><div> Tried with the new configure too. same problem: (<br> <br> $ mpirun -hostfile hosts-hydra -np 2 test_dup<br> Fatal error in MPI_Send: Unknown error class, error stack:<br> MPI_Send(174)..............: MPI_Send(buf=3D0x7fffd90c76c8, count=3D1,<br> MPI_INT, dest=3D1, tag=3D0, MPI_COMM_WORLD) failed<br> MPID_nem_tcp_connpoll(1832): Communication error with rank 1: Connection<br=
refused<br> <br> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D<u></u>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D<u></u>=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D<br> =3D BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES<br> =3D PID 5459 RUNNING AT oakmnt-0-a<br> =3D EXIT CODE: 1<br> =3D CLEANING UP REMAINING PROCESSES<br> =3D YOU CAN IGNORE THE BELOW CLEANUP MESSAGES<br> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D<u></u>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D<u></u>=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D<br> [proxy: 0:1@oakmnt-0-b] HYD_pmcd_pmip_control_cmd_cb<br> (../../../../src/pm/hydra/pm/<u></u>pmiserv/pmip_cb.c: 885): assert (!closed= ) failed<br> [proxy: 0:1@oakmnt-0-b] HYDT_dmxu_poll_wait_for_event<br> (../../../../src/pm/hydra/<u></u>tools/demux/demux_poll.c: 76): callback<br> returned error status<br> [proxy: 0:1@oakmnt-0-b] main<br> (../../../../src/pm/hydra/pm/<u></u>pmiserv/pmip.c: 206): demux engine error= <br> waiting for event<br> [mpiexec@oakmnt-0-a] HYDT_bscu_wait_for_completion<br> (../../../../src/pm/hydra/<u></u>tools/bootstrap/utils/bscu_<u></u>wait.c: 7= 6): one of<br> the processes terminated badly; aborting<br> [mpiexec@oakmnt-0-a] HYDT_bsci_wait_for_completion<br> (../../../../src/pm/hydra/<u></u>tools/bootstrap/src/bsci_wait.<u></u>c: 23)= : launcher<br> returned error waiting for completion<br> [mpiexec@oakmnt-0-a] HYD_pmci_wait_for_completion<br> (../../../../src/pm/hydra/pm/<u></u>pmiserv/pmiserv_pmci.c: 218): launcher<b= r> returned error waiting for completion<br> [mpiexec@oakmnt-0-a] main<br> (../../../../src/pm/hydra/ui/<u></u>mpich/mpiexec.c: 344): process manager e= rror<br> waiting for completion<br> <br> <br> Amin Hassani,<br> CIS department at UAB,<br> Birmingham, AL, USA.<br> <br> On Tue, Nov 25, 2014 at 11: 44 PM, Lu, Huiwei <<a href=3D"mailto:huiweilu= @mcs.anl.gov" target=3D"_blank">[email protected]</a><br></div></div><sp= an> <mailto: <a href=3D"mailto:[email protected]" target=3D"_blank">huiwei= [email protected]</a>>> wrote: <br> <br> So the error only happens when there is communication.<br> <br> It may be caused by IB as your guessed before. Could you try = to<br> reconfigure MPICH using "./configure --with-device=3Dch3= : nemesis:tcp=E2=80=9D<br> and try again?<br> <br> =E2=80=94<br> Huiwei<br> <br> > On Nov 25, 2014, at 11: 23 PM, Amin Hassani <<a = href=3D"mailto: [email protected]" target=3D"_blank">[email protected]= </a><br></span><span> <mailto: <a href=3D"mailto:[email protected]" target=3D"= _blank">[email protected]</a>>> wrote: <br> ><br> > Yes it works.<br> > output: <br> ><br> > $ mpirun -hostfile hosts-hydra -np 2 test<br=
> rank 1<br> > rank 0<br> ><br> ><br> > Amin Hassani,<br> > CIS department at UAB,<br> > Birmingham, AL, USA.<br> ><br> > On Tue, Nov 25, 2014 at 11: 20 PM, Lu, Huiwei<br></= span><span> <<a href=3D"mailto: [email protected]" target=3D"_blank"=
[email protected]</a> <mailto: <a href=3D"mailto:[email protected]= " target=3D"_blank">[email protected]</a>>> wrote: <br> > Could you try to run the following simple code to = see if it works?<br> ><br> > #include <mpi.h><br> > #include <stdio.h><br> > int main(int argc, char** argv)<br> > {<br> > int rank, size;<br> > MPI_Init(&argc, &argv);= <br> > MPI_Comm_rank(MPI_COMM_WORLD, &= amp;rank);<br> > printf("rank %d\n", r= ank);<br> > MPI_Finalize();<br> > return 0;<br> > }<br> ><br> > =E2=80=94<br> > Huiwei<br> ><br> > > On Nov 25, 2014, at 11: 11 PM, Amin Hassani<br= </span><span> <<a href=3D"mailto: [email protected]" target=3D"_blank"= [email protected]</a> <mailto: <a href=3D"mailto:[email protected]= " target=3D"_blank">[email protected]</a>>> wrote: <br> > ><br> > > No, I checked. Also I always install my MPI's= in<br> /nethome/students/ahassani/<u></u>usr/mpi. I never install th= em in<br> /nethome/students/ahassani/<u></u>usr. So MPI files will neve= r get there.<br> Even if put the /usr/mpi/bin in front of /usr/bin, it won't a= ffect<br> anything. There has never been any mpi installed in /usr/bin.= <br> > ><br> > > Thank you.<br> > > ______________________________<u></u>________= _________<br></span> > > discuss mailing list <a href=3D"mailto: discus= [email protected]" target=3D"_blank">[email protected]</a> <mailto: <a href=3D"= mailto: [email protected]" target=3D"_blank">[email protected]</a>><span>= <br> > > To manage subscription options or unsubscribe= : <br> > > <a href=3D"https: //lists.mpich.org/mailman/li= stinfo/discuss" target=3D"_blank">https: //lists.mpich.org/<u></u>mailman/li= stinfo/discuss</a><br> ><br> > ______________________________<u></u>_____________= ____<br></span> > discuss mailing list <a href=3D"mailto: discuss@mpi= ch.org" target=3D"_blank">[email protected]</a> <mailto: <a href=3D"mailt= o: [email protected]" target=3D"_blank">[email protected]</a>><span><br> > To manage subscription options or unsubscribe: <br> > <a href=3D"https: //lists.mpich.org/mailman/listinf= o/discuss" target=3D"_blank">https: //lists.mpich.org/<u></u>mailman/listinf= o/discuss</a><br> ><br> > ______________________________<u></u>_____________= ____<br></span> > discuss mailing list <a href=3D"mailto: discuss@mpi= ch.org" target=3D"_blank">[email protected]</a> <mailto: <a href=3D"mailt= o: [email protected]" target=3D"_blank">[email protected]</a>><span><br> > To manage subscription options or unsubscribe: <br> > <a href=3D"https: //lists.mpich.org/mailman/listinf= o/discuss" target=3D"_blank">https: //lists.mpich.org/<u></u>mailman/listinf= o/discuss</a><br> <br> ______________________________<u></u>_________________<br></s= pan> discuss mailing list <a href=3D"mailto: [email protected]" tar= get=3D"_blank">[email protected]</a> <mailto: <a href=3D"mailto:discuss@m= pich.org" target=3D"_blank">[email protected]</a>><span><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" = target=3D"_blank">https: //lists.mpich.org/<u></u>mailman/listinfo/discuss</= a><br> <br> <br> <br> <br> ______________________________<u></u>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" target=3D"_bla= nk">https: //lists.mpich.org/<u></u>mailman/listinfo/discuss</a><br> <br> </span></blockquote><div><div> ______________________________<u></u>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " target=3D"_blank">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" target=3D"_bla= nk">https: //lists.mpich.org/<u></u>mailman/listinfo/discuss</a></div></div>= </blockquote></div><br></div></div></div> <br>_______________________________________________<br> discuss mailing list <a href=3D"mailto: [email protected]= ">[email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" target=3D"_bla= nk">https: //lists.mpich.org/mailman/listinfo/discuss</a><br></blockquote></= div><br></div>
--001a11c108e02e57a30508cb605e-- --===============2762240988201403401== Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: 7bit Content-Disposition: inline _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss --===============2762240988201403401==-- Message-ID: <[email protected]>
participants (1)
None
