Re: [mpich-discuss] mpich-3.3.1 cannot launch hydra_pmi_proxy in SGE
Am 14.06.2019 um 02:59 schrieb Shuwei Zhao via discuss <[email protected]>:
Hi mpich team,
My team had a issue met in mpich-3.2.1 as Xiaopeng mentioned before. As you replied, the bug was fixed in mpich-3.3.1.
However as I installed mpich-3.3.1, finished integration and launched test.
Single machine is fine. But cross machine only doesn’t work in SGE environment while it works well in lsf.
For me it still works fine. We have no SSH in the cluster and all is started solely by `qrsh -inherit …` on the slave nodes. Master of the parallel job: 11870 ? S 0:00 \_ sge_shepherd-308116 -bg 11933 ? SNs 0:00 \_ /bin/sh /var/spool/sge/node26/job_scripts/308116 11934 ? SN 0:00 \_ mpiexec ./mpihello 11935 ? SNs 0:00 \_ /home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 0 11942 ? RNs 1:43 | \_ ./mpihello 11943 ? RNs 1:43 | \_ ./mpihello 11936 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node28 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 1 11937 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node27 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 2 11938 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node25 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 3 11939 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node24 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 4 11940 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node29 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 5 11941 ? SNsl 0:00 \_ /usr/sge/bin/lx24-em64t/qrsh -inherit -V node23 "/home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy" --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 6 One of the slaves: 3904 ? Sl 958:10 /usr/sge/bin/lx24-em64t/sge_execd 4012 ? S 14:55 \_ /bin/sh /usr/sge/cluster/tmpspace.sh 17401 ? Sl 0:00 \_ sge_shepherd-308116 -bg 17402 ? SNs 0:00 \_ /usr/sge/utilbin/lx24-em64t/qrsh_starter /var/spool/sge/node23/active_jobs/308116.1/1.node23 17409 ? SN 0:00 \_ /home/reuti/local/mpich-3.3.1_gcc-6.5.0/bin/hydra_pmi_proxy --control-port node26:40054 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 6 17410 ? RNs 0:38 \_ ./mpihello -- Reuti
mpich-3.2.1
mpich-3.3.1
Relevant processes greped out using “ps -eo user,pid,ppid,cmd”
sgeadmin 2288 3938 sge_shepherd-768144 -bg
sgeadmin 2317 3938 sge_shepherd-768145 -bg
szhao 2367 2317 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/bin/mpich/mpiexec -n 1 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/bin/finesim my_command_line_argument
szhao 2368 2288 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/bin/mpich/mpiexec -n 1 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/bin/finesim my_command_line_arguments
szhao 2372 2368 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/bin/mpich/hydra_pmi_proxy --control-port broad1029.internal.synopsys.com:39346 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 0
szhao 2373 2367 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/bin/mpich/hydra_pmi_proxy --control-port broad1029.internal.synopsys.com:44694 --rmk sge --launcher sge --demux poll --pgid 0 --retries 10 --usize -2 --proxy-id 0
szhao 2374 2372 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/platform/linux64/finesim my_command_line_arguments
szhao 2375 2373 /remote/swefs1/PE/products/cktsim/p2019.06_rel/image/nightly/finesim_optimize/D20190611_5647184/Testing/finesim/platform/linux64/finesim my_command_line_arguments
sgeadmin 3938 1 /remote/sge3/default/bin/lx-amd64/sge_execd
sgeadmin 11119 3158 sge_shepherd-801927 -bg
sgeadmin 11151 3158 sge_shepherd-801928 -bg
szhao 11149 11119 /slowfs/finesim6/users/szhao/src/finesim/cktsim_dev/snps/finesim/optimize/finesim/bin/mpich/mpiexec -n 1 /slowfs/finesim6/users/szhao/src/finesim/cktsim_dev/snps/finesim/optimize/bin/finesim my_command_line_argument
szhao 11180 11151 /slowfs/finesim6/users/szhao/src/finesim/cktsim_dev/snps/finesim/optimize/finesim/bin/mpich/mpiexec -n 1 /slowfs/finesim6/users/szhao/src/finesim/cktsim_dev/snps/finesim/optimize/bin/finesim -o xxx -new_flow input.sp -DEBUG -ns 1 -dpmt_flow -dscale xxx.dynamic -pmc
szhao 11150 11149 [qrsh] <defunct>
szhao 11181 11180 [qrsh] <defunct>
sgeadmin 3158 1 /remote/sge3/default/bin/lx-amd64/sge_execd
Processes spawned procedure
From above, we can see that process spawned like this:
Sge_execd -> sge_shepherd > mpiexec -> hydra_pmi_proxy -> my_process
Sge_execd -> sge_shepherd > mpiexec -X-> hydra_pmi_proxy -> my_process
If you are able to track the pid and ppid, Looks like hydra_pmi_proxy is unable to spawn when run with mpich-3.3 on sge environment. Could you please help confirm is it a potential bug or there is something that I didn’t take care of?
Shuwei
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Reuti
