Re: [mpich-discuss] (no subject)
Hi Maxim, This issue is fixed in the MPICH master repository. You can try a 3.2 beta release or one of the recent nightly builds here: http://www.mpich.org/static/downloads/nightly/master/ Ken On 06/03/2015 04:44 AM, Maxim Abalenkov wrote:
Dear all,
I believe I have encountered a minor bug in the MPICH 3.1.4 implementation. Following the 'README' advice for configuration flags for performance runs I have used the flag '--disable-error-checking'. Configure works fine, but the compilation fails at the file 'info_get.c', where the program tries to use the label 'fn_fail', that is __not__ defined in case the error checks are __disabled__. I have tried to configure and compile with both Intel and GNU Fortran compilers. The problem persists in both cases. Please see the attached TAR archive for 'c.txt' and 'm.txt' log files. Thank you.
-- Kind regards, Maxim Abalenkov
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
