Re: [mpich-discuss] MPI log via MPE on CRAY XC30 machine
To answer this question, MPE doesn’t do anything elaborate. It defines its own implementation of all of the MPI (1 and 2) functions, and calls the relevant PMPI versions to perform the actions. Thus, if you have object files, relinking with the MPE libraries is sufficient. It is not necessary to recompile any of the program. MPI_Finalize is replaced and generates the log files before calling PMPI_Finalize. As Pavan notes, if you are composing several systems, the PNMPI tool is a good choice. Bill On Sep 17, 2014, at 12:32 PM, Milind Chabbi <[email protected]> wrote:
Can you tell me how MPE2 achieves the logging? Does it divert MPI_ calls through its own functions? On static libraries does it use linker wrapping? For a large application simply changing the last linker step to use mpecc would suffice or does it need the whole application to be recompiled with mpecc wrapper?
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
William Gropp
