Re: [mpich-discuss] MPI_Cancel + MPI_Wait stalls when using ch4, not when using ch3
Instead of stalling, it would be better to detect send cancel and throw an error. Jeff On Wed, Feb 2, 2022 at 2:16 AM Zhou, Hui via discuss <[email protected]> wrote:
Hi Edric,
After some pondering, we are closing https://github.com/pmodels/mpich/issues/5775 as wontfix. For the following reasons:
- Cancelling send is deprecated in MPI-4. - The potential fix will be very messy due to current design. - On the other hand, it is probably easier to work around in application.
Example workaround could be to replace MPI_Issend with `MPI_Isend` plus separate MPI_Irecv for acknowledgement. You only need do this for the MPI_Issend that you may cancel, and I think it is a small inconvenience for more predictable behavior. Internally an MPI_Issend is not implemented as an MPI_Isend + MPI_Irecv to be more efficient and to exploit hardware acceleration where we can, but that also made cancelling it very complicated.
If you have strong reasons to fix this issue, for example, no feasible work around, let's discuss.
-- Hui Zhou
------------------------------ *From:* Zhou, Hui <[email protected]> *Sent:* Wednesday, January 19, 2022 12:28 PM *To:* [email protected] <[email protected]> *Cc:* Edric Ellis <[email protected]> *Subject:* Re: MPI_Cancel + MPI_Wait stalls when using ch4, not when using ch3
Thanks for reporting. We'll fix this. Tracking issue: https://github.com/pmodels/mpich/issues/5775 <https://github.com/pmodels/mpich/issues/5775> ch4: MPI_Cancel stalls MPI_Wait · Issue #5775 · pmodels/mpich <https://github.com/pmodels/mpich/issues/5775> Reported on discuss mailinglist: ---- quote ---- Hi, Running one of our test programs using MPICH 3.4.3 and ch4:ofi, I notice that MPI_Wait on an MPI_Request that has been MPI_Cancelled never compl... github.com
------------------------------ *From:* Edric Ellis via discuss <[email protected]> *Sent:* Wednesday, January 19, 2022 11:21 AM *To:* [email protected] <[email protected]> *Cc:* Edric Ellis <[email protected]> *Subject:* [mpich-discuss] MPI_Cancel + MPI_Wait stalls when using ch4, not when using ch3
Running one of our test programs using MPICH 3.4.3 and ch4:ofi, I notice that MPI_Wait on an MPI_Request that has been MPI_Cancelled never completes (it does when using ch3). (The documentation for MPI_Cancel states "If a communication is marked for cancellation, then a MPI_WAIT call for that communication is guaranteed to return, irrespective of the activities of other processes (i.e., MPI_WAIT behaves as a local function)")
Here's a simple example:
#include <mpi.h> #include <stdio.h> #include <stdlib.h>
void check(int const value) { if (value != MPI_SUCCESS) { fprintf(stderr, "Failed.\n"); exit(1); } }
int main(int argc, char** argv) { MPI_Request r1; int payload = 42; int result;
check(MPI_Init(0,0)); check(MPI_Issend(&payload, 1, MPI_INT, 0, 0, MPI_COMM_WORLD, &r1)); check(MPI_Test(&r1, &result, MPI_STATUS_IGNORE)); fprintf(stdout, "MPI_Test result: %d\n", result); check(MPI_Cancel(&r1)); check(MPI_Wait(&r1, MPI_STATUS_IGNORE)); MPI_Finalize(); return 0; }
This stalls in MPI_Wait when executed using "mpiexec -n 1 ./a.out".
Cheers, Edric.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
