Re: [mpich-discuss] mpifort wrapper compiler?
The point is that MPI shouldn't try to subvert what the underlying Fortran compilers are doing. If they're consolidating down to a single name, so should we. And if you have platforms where they're not, great -- don't consolidate to a single name (e.g., mpifort) on those platforms, and/or rely on downstream vendors (e.g., IBM) to do the right things for their platforms/compiler suites (e.g., the mpif* scripts that IBM is apparently generating).
I agree that this is right for most cases, eg ifort, ftn and gfortran. I recall PGI has language-named variants. Not sure what you think should be done there. That is a case that actually matters to MPICH and OpenMPI builds from source by users (as opposed to IBM on BG).
The Absoft compiler also has different names af77 and af90. Rajeev
participants (1)
Rajeev Thakur
