Re: [mpich-discuss] How to terminate MPI_Comm_accept
Hi Hirak, I checked your code. I think your code is incorrect because you are trying to establish communication within a single process. You are using two threads and two duplicated communicators, but they are associated with a single process. MPI_Comm_accept() and MPI_Comm_connect() are used to establish communication between “two sets of MPI processes” (i.e., at least two different processes are needed). Please refer to 10.4 Establishing Communication (p. 387) in MPI Standard 3.0. — Sangmin On Oct 8, 2014, at 3:46 PM, Roy, Hirak <[email protected]<mailto:[email protected]>> wrote: Hi Pavan, Here is the code attached. Let me know if you think the code is incorrect. I used MPI-3.0.4 with sock device. Compile command : export MPI_ROOT = /home/hroy/local/mpich-3.0.4/linux_x86_64 #export MPI_ROOT = /home/hroy/local/mpich-3.0.4.nemesis/linux_x86_64 export MPI_BIN = ${MPI_ROOT}/bin export MPI_LIB = ${MPI_ROOT}/lib export INCLUDE_DIR = ${MPI_ROOT}/include compile: g++ -g main.cpp -I ${INCLUDE_DIR} ${MPI_LIB}/libmpich.a ${MPI_LIB}/libmpl.a -lpthread Thanks, Hirak Can you send us a simple program that reproduces the issue? — Pavan On Oct 8, 2014, at 2:54 PM, Roy, Hirak <Hirak_Roy at mentor.com<https://lists.mpich.org/mailman/listinfo/discuss>> wrote:
Hi Pavan,
I even tried duping the communicator (MPI_COMM_SELF à DUP1, DUP2) before I do any kind of MPI calls.
Still it does not work.
Hirak
<main.cpp>_______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Seo, Sangmin
