Re: [mpich-discuss] "undefined references"
We're not going to be able to help you debug other packages here. You're going to need to talk to the Siesta people about this. On Jul 8, 2013, at 12:15 PM, Hana Milani <[email protected]> wrote:
I have also tried to install serial Siesta and "make" gen basis. Here is the error I get:
alloc.o basis_types.o precision.o recipes.o parallel.o parsing.o xcmod.o basis_io.o chemical.o atm_transfer.o atm_types.o atmparams.o old_atmfuncs.o radial.o io.o paste.o flib_spline.o bessph.o m_filter.o basis_specs.o atom.o memoryinfo.o memory.o periodic_table.o pseudopotential.o pxf.o dot.o xc.o atom_options.o arw.o sys.o timer.o xml.o m_walltime.o gen-basis.o nag.o libfdf.a dc_lapack.a liblapack.a libblas.a f95: error: dc_lapack.a: No such file or directory f95: error: liblapack.a: No such file or directory f95: error: libblas.a: No such file or directory make: *** [gen-basis] Error 1
why should it ask for liblapack when I have installed siesta in parallel with absolutely n change in arch.make !!!!
From: Jeff Hammond <[email protected]> To: Hana Milani <[email protected]>; [email protected] Sent: Monday, July 8, 2013 8:56 PM Subject: Re: [mpich-discuss] "undefined references"
I looked through the code and suspect Siesta is at fault but since they rolled their own MPI F90 wrappers and I know very little about F90, I cannot debug it.
You will see that there are no wrappers for send, recv, bcast or reduce (the functions for which you get errors) in ./Src/MPI/mpi.F. There are references to these in ./Src/MPI/mpi__*.f90 but I don't understand what's going on very well. It also appears that these files are from a prototype implementation of the F90 module for MPI 1.1 written in 1996. I don't know if that was before the MPI standard defined F90 bindings, but it surely does now and applications should use those instead.
The other thing you can do is turn off MPI in the utility code since it might not be necessary there.
Jeff
On Mon, Jul 8, 2013 at 11:09 AM, Hana Milani <[email protected]> wrote:
yes, apologies
________________________________ From: Hana Milani <[email protected]> To: Pavan Balaji <[email protected]> Sent: Monday, July 8, 2013 7:53 PM
yes Pavan, But it's a long time I have not received any response
________________________________ From: Pavan Balaji <[email protected]> To: Hana Milani <[email protected]>; [email protected] Sent: Monday, July 8, 2013 7:03 PM
This doesn't look like an MPI error. Did you contact the authors of whatever package you are trying to compile?
-- Pavan
On 07/08/2013 08:25 AM, Hana Milani wrote:
Hello,
I have compiled a code (siesta) by mpich2, blacs, lapack, blas and scalapack. It works fine under grid computation. But when I want to "make" a utility, I receive the following errors:
[Home@localhost Gen-basis]$ make /usr/local/bin/mpif90 -o gen-basis \ alloc.o basis_types.o precision.o recipes.o parallel.o parsing.o xcmod.o basis_io.o chemical.o atm_transfer.o atm_types.o atmparams.o old_atmfuncs.o radial.o io.o paste.o flib_spline.o bessph.o m_filter.o basis_specs.o atom.o memoryinfo.o memory.o periodic_table.o pseudopotential.o pxf.o dot.o xc.o atom_options.o arw.o sys.o timer.o xml.o m_walltime.o gen-basis.o nag.o libfdf.a /home/Home/Packages/scalapack-2.0.2/libscalapack.a /home/Home/Packages/BLACS/LIB/blacsCinit_MPI-LINUX-0.a /home/Home/Packages/BLACS/LIB/blacsF77init_MPI-LINUX-0.a /home/Home/Packages/BLACS/LIB/blacs_MPI-LINUX-0.a /home/Home/Packages/lapack-3.4.2/liblapack.a /home/Home/Packages/BLAS/blas_LINUX.a alloc.o: In function `print_report':
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:1705: undefined reference to `__mpi__r8_s_MOD_mpi_reduce_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:1707: undefined reference to `__mpi__r8_v_MOD_mpi_reduce_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:1711: undefined reference to `__mpi__integer_s_MOD_mpi_bcast_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:1723: undefined reference to `__mpi__r8_s_MOD_mpi_recv_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:1718: undefined reference to `__mpi__r8_s_MOD_mpi_send_t' alloc.o: In function `__alloc_MOD_alloc_report':
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:318: undefined reference to `__mpi__integer_s_MOD_mpi_bcast_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:319: undefined reference to `__mpi__integer_s_MOD_mpi_bcast_t'
/home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/alloc.F90:320: undefined reference to `__mpi__character_s_MOD_mpi_bcast_t' xcmod.o: In function `__xcmod_MOD_setxc': /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/xcmod.F:136: undefined reference to `__mpi__integer_s_MOD_mpi_bcast_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/xcmod.F:138: undefined reference to `__mpi__character_v_MOD_mpi_bcast_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/xcmod.F:140: undefined reference to `__mpi__character_v_MOD_mpi_bcast_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/xcmod.F:142: undefined reference to `__mpi__r8_v_MOD_mpi_bcast_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/xcmod.F:144: undefined reference to `__mpi__r8_v_MOD_mpi_bcast_t' memory.o: In function `printmemory_': /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/memory.F:144: undefined reference to `__mpi__integer_s_MOD_mpi_allreduce_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/memory.F:167: undefined reference to `__mpi__integer_sv_MOD_mpi_gather_t' timer.o: In function `timer1_': /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/timer.F:117: undefined reference to `__mpi__r8_s_MOD_mpi_allreduce_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/timer.F:164: undefined reference to `__mpi__r8_v_MOD_mpi_reduce_t' /home/Home/Packages/siesta-TEST-3.2/Util/Gen-basis/../../Src/timer.F:139: undefined reference to `__mpi__r8_v_MOD_mpi_reduce_t' collect2: error: ld returned 1 exit status make: *** [gen-basis] Error 1
I will be really grateful if you kindly help me to solve this problem.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
-- Jeff Hammond [email protected]
participants (1)
Wesley Bland
