Re: [mpich-discuss] Behavioral change for MPI_Ibarrier(MPI_COMM_SELF, &r) in mpich-3.2
"Jeff Squyres (jsquyres)" <[email protected]> writes:
In short: yes, this is a micro-optimization. But:
a) it kinda falls in the "violates the law of least astonishment" category b) is deallocating a free listed request that expensive? c) if you have to explain this every time, are you really optimizing anything?
Agreed on the above points. I just think that if returning MPI_REQUEST_NULL is valid, it needs to be explicitly allowed by the standard. My preference is to not allow it because it can make logic simpler and make memory leaks easier to debug.
d) it's a single process case -- it's already damn fast. Do you really need to optimize it further? :-)
This is more delicate because having a fast serial path is important to avoid code duplication when certain base cases are performance sensitive (or when running one-process jobs). This can arise even for tightly coupled problems at large scale, e.g., in the "coarse" levels of various fast algorithms. In this particular circumstance, I think you'd be hard-pressed to find a use case where the overhead is detectable, and it's arguably less code complexity to short-circuit the whole operation in the serial case than to add an extra flag variable to be able to accommodate the possibility that MPI_REQUEST_NULL is returned. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jed Brown
