Re: [mpich-discuss] MPICH 3.1 fails doesn't create core file.
Thank you for an advice. Unfortunately I can't change input data rate (from external source). We are working on slow down input rate. Using debugger cause execution slowdown an we can't deal with current data rate. Regards, Anatoly. On Mon, Oct 13, 2014 at 8:03 AM, James <[email protected]> wrote:
You could try running the master process under gdb. If it terminates abnormally - e.g. something like a segfault - you can then do a backtrace to find out where the problem is happening. Or if you get a "program terminated normally" message, then you know that it's following some code path that causes it to terminate.
James
On Sun, 12 Oct 2014 20:42:33 -0700, Anatoly G <[email protected]> wrote:
I'm not sure about my current failure.
I execute my application (MPI processes). Each process executes endless loop. After a couple of hours Master process fails (disappears - I can't see it using 'ps' command). There is no core file. I'm not sure about the reason of failure. It looks strange that single process (15 processes executed) fails w/o core file dropping. I suspect that I'm using MPICH in wrong way, which causes failure. But like I said before I'm not sure about failure.
Regards, Anatoly.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Anatoly G
