Re: [mpich-discuss] MPI process killed and SIGUSR1
You will only receive the notification if you use a communicating call. That call doesn't do any communication so it won't return the error.
On Oct 9, 2014, at 11:37 AM, Roy, Hirak <[email protected]> wrote:
Hi Pavan and Wesley,
Thanks Pavan for the information.
Wesley,
If I try MPI_Comm_remote_size periodically, then should I get Error-code, when the client on the other side of the intercom is killed ? ( I have already used MPI_ERRORS_RETURN).
Thanks, Hirak
MPICH should detect and notify you about process failures without you having to install your own signal handler. You’ll be notified via the return code on your MPI call. You can also use an MPI Errhandler to catch this notification. So once you’ve set up your intercommunicator between your two processes, you should be able to change the default errhandler from MPI_ERRORS_ABORT to your own custom error handler (or just use MPI_ERRORS_RETURN and check the return codes).
If you’re asking about the implementation of the proposed fault tolerance features for MPI-4 in MPICH, that’s a work in progress. We hope to have something for the MPICH 3.2 release cycle, but it’s not guaranteed and it will still be a very experimental feature given that the MPI Forum has not yet actually adopted the fault tolerance proposal.
Thanks, Wesley
On Oct 9, 2014, at 11:12 AM, Balaji, Pavan <balaji at anl.gov> wrote:
I’ll let Wesley answer the FT notification part.
MPI-4 is a major standard release of MPI. That’ll take a few years. We are currently working on the MPI-3.1 release. (hopefully you know the difference between MPI and MPICH, otherwise it’ll take many emails to explain that part :-) ).
— Pavan
On Oct 9, 2014, at 11:09 AM, Roy, Hirak <Hirak_Roy at mentor.com> wrote:
Hi Pavan,
Just wondering with the current release whether we have any way to notify the server that client is terminated unexpectedly! Another point: When do we expect to have MPI-4 release out?
Thanks, Hirak
Please don’t rely on this feature. We are preparing for MPI-4 Fault Tolerance and are in the process of reworking a bunch of this stuff. This might or might not exist in the future if you are planning to use this for production code.
— Pavan
On Oct 9, 2014, at 10:57 AM, Roy, Hirak <Hirak_Roy at mentor.com> wrote:
Hi Sangmin,
The readme of mpich says the following :
FAILURE NOTIFICATION: THIS IS AN UNSUPPORTED FEATURE AND WILL ALMOST CERTAINLY CHANGE IN THE FUTURE!
In the current release, hydra notifies the MPICH library of failed processes by sending a SIGUSR1 signal. The application can catch this signal to be notified of failed processes. If the application replaces the library's signal handler with its own, the application must be sure to call the library's handler from it's own handler. Note that you cannot call any MPI function from inside a signal handler.
If this is true, should not I expect SIGUSR1?
Thanks, Hirak First of all, MPI functions are not signal safe. So, if you try to use signals within your MPI program, things might break.
— Sangmin
On Oct 9, 2014, at 7:37 AM, Roy, Hirak <Hirak_Roy at mentor.com<mailto:Hirak_Roy at mentor.com>> wrote:
Hi ,
I have two MPI processes (server and client) launched independently by two different mpiexec command. (mpich-3.0.4, sock-device) 1> mpiexec –disable-auto-cleanup –n 1 ./server 2> mpiexec –disable-auto-cleanup –n 1 ./client
The server opens a port and does MPI_Comm_accept. The client gets the port information and does MPI_Comm_connect and hence we get a new intercommunicator. I don’t do MPI_Comm_merge.
I have installed my own signal handler for SIGUSR1 before even I call MPI_Init ( I guess, this will automatically chain the signal handler).
signal (SIGUSR1, mysignalhandler);
Now suppose, the ‘client’ process gets killed ( I forcefully kill the process by signal 9), I thought I would get SIGUSR1 in the process ‘server’. However, I don’t get any signal in ‘server’ process. Am I doing something wrong? I have noticed that if I start 4 client processes with single mpiexec command, and one client gets killed, rest of the 3 clients receive SIGUSR1.
Does this mean, SIGUSR1 is not forwarded across processes connected using inter-communicator?
Thanks, Hirak
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
