Re: [mpich-discuss] [petsc-dev] Is mpich/master:a8a2b30fd21 tested with Petsc?
On Tue, 13 Mar 2018, Eric Chamberland wrote:
each night we are testing mpich/master with our petsc-based code.ᅵ I don't know if PETSc team is doing the same thing with mpich/master?ᅵᅵ (Maybe it is a good idea?)
Everything was fine (except the issue https://github.com/pmodels/mpich/issues/2892) up to commit 7b8d64debd, but since commit mpich:a8a2b30fd21), I have a segfault on a any parallel nightly test.
I attempted a bisect of the above range of commits - and narrowed down to:
db11d4c4a70e39a28be88ed32f00542301699e08 is the first bad commit <<<<<<<
balay@asterix /home/balay/soft/build/mpich ((db11d4c4a...)|BISECTING) $ git show db11d4c4a70e39a28be88ed32f00542301699e08 commit db11d4c4a70e39a28be88ed32f00542301699e08 (HEAD, refs/bisect/bad) Author: Ken Raffenetti <[email protected]> Date: Thu Feb 15 11:37:59 2018 -0600
init: Fix tag upper limit initialization The starting point for this value is equivalent to the usable tag bits macro. This value should be set before device initialization, otherwise devices will assume they have more bits than are actually available. Signed-off-by: Wesley Bland <[email protected]> diff --git a/src/mpi/init/initthread.c b/src/mpi/init/initthread.c index cbc41f4d5..b31ae2f07 100644 --- a/src/mpi/init/initthread.c +++ b/src/mpi/init/initthread.c @@ -403,7 +403,7 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided) MPIR_Process.attrs.host = MPI_PROC_NULL; MPIR_Process.attrs.io = MPI_PROC_NULL; MPIR_Process.attrs.lastusedcode = MPI_ERR_LASTCODE; - MPIR_Process.attrs.tag_ub = 0; + MPIR_Process.attrs.tag_ub = MPIR_TAG_USABLE_BITS; MPIR_Process.attrs.universe = MPIR_UNIVERSE_SIZE_NOT_SET; MPIR_Process.attrs.wtime_is_global = 0; @@ -531,13 +531,6 @@ int MPIR_Init_thread(int *argc, char ***argv, int required, int *provided) MPIR_Assert(((unsigned) MPIR_Process. attrs.tag_ub & ((unsigned) MPIR_Process.attrs.tag_ub + 1)) == 0); - /* Set aside tag space for tagged collectives and failure notification */ -#ifdef HAVE_TAG_ERROR_BITS - MPIR_Process.attrs.tag_ub >>= 3; -#else - MPIR_Process.attrs.tag_ub >>= 1; -#endif - /* Assert: tag_ub is at least the minimum asked for in the MPI spec */ MPIR_Assert(MPIR_Process.attrs.tag_ub >= 32767); <<<<<<<<<<<<<<<<< Reverthing this patch gets mpich-3.3b2 working with petsc Satish _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Satish Balay
