Re: [mpich-discuss] Mpich failure with external libfabric on macOS: OFI resource bind failed
The libfabric version is 1.12.1 Here is the log as asked: ==== Capability set configuration ==== libfabric provider: udp;ofi_rxd MPIDI_OFI_ENABLE_AV_TABLE: 1 MPIDI_OFI_ENABLE_SCALABLE_ENDPOINTS: 0 MPIDI_OFI_ENABLE_SHARED_CONTEXTS: 0 MPIDI_OFI_ENABLE_MR_SCALABLE: 0 MPIDI_OFI_ENABLE_MR_VIRT_ADDRESS: 0 MPIDI_OFI_ENABLE_MR_ALLOCATED: 0 MPIDI_OFI_ENABLE_MR_PROV_KEY: 0 MPIDI_OFI_ENABLE_TAGGED: 1 MPIDI_OFI_ENABLE_AM: 1 MPIDI_OFI_ENABLE_RMA: 1 MPIDI_OFI_ENABLE_ATOMICS: 1 MPIDI_OFI_FETCH_ATOMIC_IOVECS: 1 MPIDI_OFI_ENABLE_DATA_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_CONTROL_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_PT2PT_NOPACK: 1 MPIDI_OFI_ENABLE_HMEM: 0 MPIDI_OFI_NUM_AM_BUFFERS: 8 MPIDI_OFI_CONTEXT_BITS: 20 MPIDI_OFI_SOURCE_BITS: 0 MPIDI_OFI_TAG_BITS: 31 ====================================== MAXIMUM SUPPORTED RANKS: 4294967296 MAXIMUM TAG: 2147483648 ====================================== Abort(1615247) on node 0 (rank 0 in comm 0): Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(152).......: MPID_Init(597)..............: MPIDI_OFI_mpi_init_hook(674): create_vni_context(964).....: OFI resource bind failed (ofi_init.c:964:create_vni_context:No message available on STREAM) … Michka
On 4 May 2021, at 00:53, Zhou, Hui <[email protected]> wrote:
Hi Michka,
Which libfabric version are you using? Could you try setting `MPIR_CVAR_CH4_OFI_CAPABILITY_SETS_DEBUG=` to see if there is more debug messages?
-- Hui Zhou From: Michka Popoff via discuss <[email protected]> Sent: Saturday, May 1, 2021 4:33 PM To: [email protected] <[email protected]> Cc: Michka Popoff <[email protected]> Subject: [mpich-discuss] Mpich failure with external libfabric on macOS: OFI resource bind failed
Hi
Homebrew maintainer here (https://github.com/Homebrew <https://github.com/Homebrew>). Homebrew ships mpich as a package on both MacOS and Linux.
The issue below was found with version 3.4.1 but might have been there for longer.
We noticed that mpich was building it’s own internal libfabric dependency. After reading https://lists.mpich.org/pipermail/discuss/2021-January/006092.html <https://lists.mpich.org/pipermail/discuss/2021-January/006092.html>, we added `--with-device=ch4:ofi` and set the libfabric path with the --with-libfabric= flag, to use our own version.
The build is fine. We have a small test to check if mpich is still working fine;
#include <mpi.h> #include <stdio.h> int main() { int size, rank, nameLen; char name[MPI_MAX_PROCESSOR_NAME]; MPI_Init(NULL, NULL); MPI_Comm_size(MPI_COMM_WORLD, &size); MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Get_processor_name(name, &nameLen); printf("[%d/%d] Hello, world! My name is %s.\\n", rank, size, name); MPI_Finalize(); return 0; }
Executing the test fails with a weird error:
/usr/local/Cellar/mpich/3.4.1_2/bin/mpicc hello.c -o hello ./hello Abort(1615247) on node 0 (rank 0 in comm 0): Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(152).......: MPID_Init(597)..............: MPIDI_OFI_mpi_init_hook(674): create_vni_context(964).....: OFI resource bind failed (ofi_init.c:964:create_vni_context:No message available on STREAM) [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1615247 : system msg for write_line failure : Bad file descriptor Abort(1615247) on node 0 (rank 0 in comm 0): Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(152).......: MPID_Init(597)..............: MPIDI_OFI_mpi_init_hook(674): create_vni_context(964).....: OFI resource bind failed (ofi_init.c:964:create_vni_context:No message available on STREAM) [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1615247 : system msg for write_line failure : Bad file descriptor
This test passes fine on Linux, and fails only on MacOS. Using the internal libfabric is fine on both platforms.
Here is the related discussion: https://github.com/Homebrew/homebrew-core/pull/73062 <https://github.com/Homebrew/homebrew-core/pull/73062>
Maybe you could help us debug this issue?
Regards
Michka
participants (1)
Michka Popoff
