Re: [mpich-discuss] Fatal error in PMPI_Reduce
Hi Pavan ~ I'm only using two hosts in this test. cxxcpi works successfully on any one host (n <= 16) but fails on any two hosts (n > 16). So whatever the issue is it's systematic to all the systems (which I suppose makes sense). All these systems have firewalls disabled so I can confirm that firewall is not an issue. The only thing that's not completely standard is they use a bond of several eth devices for communication and some fancier load-balancing network equipment. That should all be external to the OS however. I'm almost ready to test out the little VM test network; I will report what I find. Thanks, ~Mike C. -----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: Saturday, January 12, 2013 10:34 AM To: Michael Colonno Cc: [email protected] Subject: Re: [mpich-discuss] Fatal error in PMPI_Reduce Hi Michael, On 01/12/2013 12:29 PM US Central Time, Michael Colonno wrote:
Thanks for the reply. I did verify connectivity prior to trying the program. In this test case I have two systems, each with 16 cores (cv-hpcn1 and cv-hpcn2). ssh between the two systems appears to be working as far as I can tell:
Even if ssh is working, there might still be problems. For example, many firewalls allow ssh (port 22), but not other ports. So even if ssh appears to be working, MPICH cannot. Similarly, if one of the nodes has a messed up /etc/hosts file pointing to a wrong IP address for another host, again mpich will fail. My recommendation would be to use selectively remove hosts from your host file to figure out the problematic host first.
cv-hpcn1$ /usr/local/apps/MPICH2/standalone/bin/mpirun -n 32 -f /usr/local/apps/hosts /usr/local/apps/cxxcpi
FWIW, in a SLURM environment, mpiexec/mpirun automatically detects the default "-f" parameter. You can override it with whatever you want, but if you want to use the default set of allocated hosts, -f is not required. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Michael Colonno
