Re: [mpich-discuss] MPICH configure
Hi Bruce, I noticed you are mixing up things a bit, so let’s clear it up first: * If you compile with slurm then you should only launch with srun, not mpirun. Otherwise it won’t work. * If you compile without slurm, then you should launch with mpirun, or more precisely, mpiexec.hydra. Depend on which you are doing, each may have issues in your envioronment, but whatever issues are probably unrelated, and should not be discussed in a same context. What is working with your with 3.3.1? With slurm? If that’s what’s working for you, then let’s focus on compile and run 3.3.2 with slurm as well. -- Hui Zhou From: "Palmer, Bruce J" <[email protected]> Date: Thursday, April 23, 2020 at 11:08 AM To: "Zhou, Hui" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure Hi Hui, I was launching the jobs with mpirun. I tried launching the jobs with srun and they no longer hang, but it looks like they are returning an MPI_COMM_WORLD with only one process, although I didn’t investigate this extensively. I also tried Pavan’s suggestion and rebuilt 3.3.2 without slurm and ran it with mpiexec. This also hangs and the error I was seeing previously reappears [proxy:0:[email protected]] HYDU_sock_connect (utils/sock/sock.c:145): unable to connect from "node168.local" to "node100.local" (Connection refused) [proxy:0:[email protected]] main (pm/pmiserv/pmip.c:183): unable to connect to server node100.local at port 54762 (check for firewalls!) srun: error: node168: task 1: Exited with exit code 5 srun: Job step aborted: Waiting up to 2 seconds for job step to finish. slurmstepd: *** STEP 13201325.0 CANCELLED AT 2020-04-23T08:58:02 *** on node100 slurmstepd: *** JOB 13201325 CANCELLED AT 2020-04-23T08:58:02 *** on node100 [[email protected]] HYDU_sock_write (utils/sock/sock.c:256): write error (Bad file descriptor) [[email protected]] HYD_pmcd_pmiserv_send_signal (pm/pmiserv/pmiserv_cb.c:178): unable to write data to proxy [[email protected]] ui_cmd_cb (pm/pmiserv/pmiserv_pmci.c:77): unable to send signal downstream [[email protected]] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:77): callback returned error status [[email protected]] HYD_pmci_wait_for_completion (pm/pmiserv/pmiserv_pmci.c:196): error waiting for event [[email protected]] main (ui/mpich/mpiexec.c:336): process manager error waiting for completion I suppose this could be a firewall issue, but there must also be some changes between 3.3.1 and 3.3.2, otherwise it should be a problem for all versions of mpich. Bruce From: "Zhou, Hui" <[email protected]> Date: Wednesday, April 22, 2020 at 10:22 AM To: "Palmer, Bruce J" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure Hi Bruce, How did you launch your jobs? Since you configured with slurm, you should launch your job with `srun`, right? -- Hui Zhou From: "Palmer, Bruce J" <[email protected]> Date: Wednesday, April 22, 2020 at 11:55 AM To: "Zhou, Hui" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure Hi Hui, Its currently 14.03.8 Bruce From: "Zhou, Hui" <[email protected]> Date: Wednesday, April 22, 2020 at 9:36 AM To: "Palmer, Bruce J" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure Hi Bruce, Thanks for the effort checking these versions. What is the slurm versions that you have on cluster? -- Hui Zhou From: "Palmer, Bruce J" <[email protected]> Date: Wednesday, April 22, 2020 at 11:02 AM To: "Zhou, Hui" <[email protected]>, "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure Hi Hui, I rebuilt everything from scratch and tried running several versions of mpich. Release 3.3.1 seems to work okay but 3.3.2 hangs. Here is a complete summary of the versions I ran 3.3rc1: Works 3.3: Works 3.3.1: Works 3.3.2: Hangs 3.4a2: Hangs I’m not seeing the error message from hydra anymore (I have no idea why not), but I logged into one of the hung processes when running with 3.3.2 and got the following listing from gdb (gdb) where #0 0x0000003d7ce0e810 in __read_nocancel () from /lib64/libpthread.so.0 #1 0x00002aaaac6e936e in PMIU_readline () from /people/d3g293/mpich/mpich-3.3.2/install/lib/libmpi.so.12 #2 0x00002aaaac6e985b in GetResponse.part.0 () from /people/d3g293/mpich/mpich-3.3.2/install/lib/libmpi.so.12 #3 0x00002aaaac6e4e36 in MPIDU_shm_seg_commit () from /people/d3g293/mpich/mpich-3.3.2/install/lib/libmpi.so.12 #4 0x00002aaaabc541dc in MPIR_Init_thread () from /people/d3g293/mpich/mpich-3.3.2/install/lib/libmpi.so.12 #5 0x00002aaaabc3db7e in PMPI_Init () from /people/d3g293/mpich/mpich-3.3.2/install/lib/libmpi.so.12 #6 0x0000000000408d0e in main () Bruce From: "Zhou, Hui" <[email protected]> Date: Monday, April 20, 2020 at 10:25 AM To: "[email protected]" <[email protected]> Cc: "Palmer, Bruce J" <[email protected]> Subject: Re: [mpich-discuss] MPICH configure The error is from `hydra`, which should not have changed much between the versions. Could you verify that 3.3.1 still works for you? -- Hui Zhou From: "Palmer, Bruce J via discuss" <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Thursday, April 16, 2020 at 5:48 PM To: "[email protected]" <[email protected]> Cc: "Palmer, Bruce J" <[email protected]> Subject: [mpich-discuss] MPICH configure Hi, I’ve been building MPICH on are aging Infiniband cluster using the following formula ./configure --prefix=/people/d3g293/mpich/mpich-3.3.2/install --with-device=ch4:ofi:sockets --with-libfabric=embedded --enable-threads=multiple --with-slurm CC=gcc CXX=g++ It’s been working pretty well but I recently tried to build mpich-3.3.2 and mpich-3.4a2 and although the build seems to work okay, I’m having problems actually running anything. If I run on 2 nodes the code seems to hang on MPI_Init and it looks like it is producing the error message [proxy:0:[email protected]] HYDU_sock_connect (utils/sock/sock.c:145): unable to connect from "node013.l ocal" to "node012.local" (Connection refused) [proxy:0:[email protected]] main (pm/pmiserv/pmip.c:183): unable to connect to server node012.local at p ort 37769 (check for firewalls!) srun: error: node013: task 1: Exited with exit code 5 If I run on a single node, things seem to work. Any idea what is going on here? I’ve got a working build of mpich-3.3, so things were okay up until recently. Has something in MPICH changed and my configuration formula is no good, or is this more likely to be due to some system modification? Bruce Palmer Senior Research Scientist Pacific Northwest National Laboratory Richland, WA 99352 (509) 375-3899
participants (1)
Zhou, Hui
