Re: [mpich-discuss] turning off MPI abort messages
Jeff Hammond <[email protected]> writes:
Did you look at my patch or the demonstration yet? I posted all the details this afternoon.
Yeah, I wrote the message on the plane before I could read it.
I tried very hard to support verbosity suppression in a reasonable way at runtime.
Do you really want an MPIX call that is equivalent to setenv("<see patch>")? Is the extra code worth it? (These are serious questions.)
My understanding of these variables is that they are processed in MPI_Init. PETSc may not have access to MPI_Init, so we're too late to influence the environment variable. But if the user gets a return code and calls our error-handler (as we encourage them to do if they have nothing better to do with it), we'd like to be able to exit cleanly. A global setting isn't as good because if the user encounters an error condition and "crashes", it probably makes sense for MPICH to print the information. The reason this issue came up is that we have a sizable fraction of support email in which the exact question is answered in the error message we print when they call our error handler. But a lot of users don't read the error message and worse, they don't copy the whole thing into the email. This happens almost every day and requires an extra round-trip on the list the resolve. Our thinking was that if we can make the error message visually cleaner, they may be more likely to read it and answer their own question or copy the message into an email in which case we can ask them to read the relevant lines of the error message. (A large fraction of these issues are because the user has configured something incompatible, usually via run-time options. It is very analogous to asking for a file that doesn't exist. A straightforward change of run-time options will get them running correctly.) The MPICH Abort messages add a lot of visual clutter that we hypothesize makes people less likely to read our messages (telling them how to fix the problem), or to believe the output does not have useful information. I think something along the lines of MPIX_Abort_quietly(comm,err) would be the right granularity since it allows our error handler to suppress the clutter without influencing the behavior observed in other libraries or the application.
participants (1)
Jed Brown
