Re: [mpich-discuss] MPICH 3.1 fails doesn't create core file.
I'm not sure about my current failure. I execute my application (MPI processes). Each process executes endless loop. After a couple of hours Master process fails (disappears - I can't see it using 'ps' command). There is no core file. I'm not sure about the reason of failure. It looks strange that single process (15 processes executed) fails w/o core file dropping. I suspect that I'm using MPICH in wrong way, which causes failure. But like I said before I'm not sure about failure. Regards, Anatoly. On Mon, Oct 13, 2014 at 6:21 AM, Wesley Bland <[email protected]> wrote:
Calling MPI_Abort is not an error that would cause the OS to dump a core. For that, you'll need to do something within your application that would normally cause it to dump a core. MPICH itself won't do it for you. You can add a divide by zero error to your own code and you'll get a core file of your app. What specifically within MPICH are you trying to debug?
Thanks, Wesley
On Oct 12, 2014, at 10:09 PM, Anatoly G <[email protected]> wrote:
Thank you. My OS (Kubuntu 14.04). ulimit is already set to unlimited. When I generate exception (abort() function or divide by zero) I always get a core file, but when MPICH fails (for example with MPI_Abort) no core file created. May be I need to change any other settings?
Regards, Anatoly.
On Sun, Oct 12, 2014 at 4:47 PM, Lu, Huiwei <[email protected]> wrote:
The core file is created by the OS, not MPICH. What’s the output of ‘ulimit -c’ on your machine? Could you set ‘ulimit -c unlimited’ and try again?
— Huiwei
On Oct 12, 2014, at 7:35 AM, Anatoly G <[email protected]> wrote:
Dear MPICH. I'm using MPICH3.1 After application run of 4-5 hours Master process fails, but it doesn't creates a core file. When I used MPI_Abort (in the past) it not creates core file too. Can I make MPICH create core in any fail (of course if it's MPI fail).
Regards, Anatoly.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Anatoly G
