Problem with MPICH3/OpenPA on IBM P755
Hi, I am trying to compile the latest ('v3.2a2-24-g4ad367d0') nightly snapshot on the IBM P775 machine. The MPICH3 is configured with the following options: export OBJECT_MODE=64 ./configure --enable-f77 --enable-fc --enable-cxx --enable-smpcoll --with-thread-package=pthreads --with-pami=/opt/ibmhpc/pecurrent/ppe.pami --with-pami-lib=/opt/ibmhpc/pecurrent/ppe.pami/lib --with-pami-include=/opt/ibmhpc/pecurrent/ppe.pami/include64 --enable-mpe --enable-error-messages=all CC="xlc_r -q64 -qmaxmem=-1" CPP=/usr/ccs/lib/cpp CXX="xlC_r -q64 -qmaxmem=-1" F77="xlf_r -q64 -qmaxmem=-1" FC="xlf90_r -q64 -qmaxmem=-1" CFLAGS="-q64 -qmaxmem=-1" CXXFLAGS="-q64 -qmaxmem=-1" FCFLAGS="-qmaxmem=-1 -q64" FFLAGS="-q64 -qmaxmem=-1" OBJECT_MODE=64 AR="ar -X 64" --with-file-system=bg+bglockless No problem with compiling it, but there is a problem with running OpenPA tests: Testing simple integer load-linked/store-conditional functionality -SKIP- LL/SC not available Testing simple pointer load-linked/store-conditional functionality -SKIP- LL/SC not available Testing integer LL/SC ABA -SKIP- LL/SC not available Testing pointer LL/SC ABA -SKIP- LL/SC not available Testing integer load/store with 1 thread *FAILED* at test_primitives.c:371 in test_threaded_loadstore_int()... Testing pointer load/store with 1 thread *FAILED* at test_primitives.c:556 in test_threaded_loadstore_ptr()... Testing add with 1 thread *FAILED* at test_primitives.c:750 in test_threaded_add()... Testing incr and decr with 1 thread PASSED Testing decr and test with 1 thread *FAILED* at test_primitives.c:1093 in test_threaded_decr_and_test()... Testing fetch and add with 1 thread *FAILED* at test_primitives.c:1344 in test_threaded_faa()... Testing fetch and add return values with 1 thread *FAILED* at test_primitives.c:1490 in test_threaded_faa_ret()... Testing fetch and incr/decr with 1 thread PASSED Testing fetch and incr return values with 1 thread *FAILED* at test_primitives.c:1796 in test_threaded_fai_ret()... Testing fetch and decr return values with 1 thread *FAILED* at test_primitives.c:1953 in test_threaded_fad_ret()... Testing integer compare-and-swap with 1 thread *FAILED* at test_primitives.c:2191 in test_threaded_cas_int()... Testing pointer compare-and-swap with 1 thread *FAILED* at test_primitives.c:2346 in test_threaded_cas_ptr()... Testing grouped integer compare-and-swap with 1 thread *FAILED* at test_primitives.c:2506 in test_grouped_cas_int()... Testing grouped pointer compare-and-swap with 1 thread *FAILED* at test_primitives.c:2683 in test_grouped_cas_ptr()... Testing integer compare-and-swap fairness with 1 thread *FAILED* at test_primitives.c:2890 in test_threaded_cas_int_fairness()... Testing pointer compare-and-swap fairness with 1 thread *FAILED* at test_primitives.c:3087 in test_threaded_cas_ptr_fairness()... Testing integer swap with 1 thread *FAILED* at test_primitives.c:3341 in test_threaded_swap_int()... Testing pointer swap with 1 thread *FAILED* at test_primitives.c:3496 in test_threaded_swap_ptr()... Testing integer LL/SC stack -SKIP- LL/SC not available Testing pointer LL/SC stack -SKIP- LL/SC not available Testing integer LL/SC stack -SKIP- LL/SC not available Testing pointer LL/SC stack -SKIP- LL/SC not available Testing integer LL/SC stack -SKIP- LL/SC not available Testing pointer LL/SC stack -SKIP- LL/SC not available Testing integer LL/SC stack -SKIP- LL/SC not available Testing pointer LL/SC stack -SKIP- LL/SC not available ***** 16 PRIMITIVES TESTS FAILED! ***** Apparently, a bunch of tests failed. Is there anything to worry about? Or, I can simply skip these failed test and can use the compiled MPICH3 for production? The software stack used: AIX v7.1.0.0 XLC/XLF compiler v14.01.0000.0008 POE v1-1.2.0.3 Best, Victor. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Victor Vysotskiy
