Re: [mpich-discuss] MPI_LOOKUP_NAME getting wrong port back?
Fixed. At least the nameserver lookup part of it. Those [cli_1] messages remain but the application starts up and runs to completion without errors on both sides. The solution is to call MPI_Unpublish_name on the 'server' node that published the name. It's not immediately obvious from the MPI documentation that you need to do this, and I get the impression from several on-line posts in various groups it's not immediately obvious to others, either, but it makes sense. Anyway, maybe this note will be useful for posterity. So now we're just down to those mysterious error messages from what looks to be the nameserver. On Wed, Mar 21, 2018 at 2:10 PM, Alexander Rast < [email protected]> wrote:
More information: this looks as if it may be a bug in hydra_nameserver. I found the following:
If you start up the hydra_nameserver, and do an mpiexec with both my 'server' and 'client' groups, *the first time*, if you've got things set up OK, the client retrieves the right port and connects. However, if when the MPI application exits, you then try to run it a second time on both 'server' and 'client', the server gets a new port ID and appears to store it to the nameserver, BUT the client retrieves a port ID that is basically, the port ID the server had on its first run, plus some (nonrandom) garbage at the end. The garbage at the end appears to be some small slice of one of the text strings corresponding to a port ID. It seems therefore that the nameserver isn't (entirely) deleting the published port information when an MPI application exits. And then it's doing something strange when it tries to look up the same service name for a different run. If you kill the hydra_nameserver process, then when you run the applications again with 'server' and 'client' they connect.
Incidentally, I got the following errors reported from what looks to be the hydra_nameserver on one run, when the 'server' group executed MPI_COMM_ACCEPT:
[cli_1]: PMIU_parse_keyvals: unexpected key delimiter at character 96 in cmd [cli_1]: parse_keyvals failed -1
However, the 'client' group successfully connected in spite of those messages.
On Wed, Mar 21, 2018 at 12:58 AM, Alexander Rast < [email protected]> wrote:
I'm trying to test the MPI publish-connect methods and running into a situation where for some reason MPI_LOOKUP_NAME is returning the wrong port. You can see the test source and output in the attached zipfile.
I'm testing this (on Ubuntu 16.04, MPICH 3.2) by opening 2 terminal windows and starting one group of 2 processes (the 'server' group) in one, and another group (the 'client' group) in another. Beforehand I've started the hydra name server using hydra_nameserver & (in the same terminal session as the server group) The exact command line for the server group is:
mpiexec -nameserver DeepThought -n 1 ./MPI_Example_C_0 server : -n 1 ./MPI_Example_C_1 server
and for the client group:
mpiexec -nameserver DeepThought -n 1 ./MPI_Example_C_0 client : -n 1 ./MPI_Example_C_1 client
If you look at the attached output files, you can see that the problem is straightforward: MPI_LOOKUP_NAME is returning the wrong port name for the server group. Rather surprisingly, too, it *always* returns the exact same port name for any run:
tag#0$description#DeepThought$port#50178$ifname#127.0.1.1$127.0.P
even though the port name reported for the server varies: in this run it was
tag#0$description#DeepThought$port#33341$ifname#127.0.1.1$
The clients are clearly performing the lookup and successfully querying the nameserver because if I don't run the server and simply run the clients they abort saying they couldn't find a published port, as expected.
So something strange is going on. Has anyone run into this? Is there something I need to do otherwise?
Thanks for any help.
Alex Rast
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Alexander Rast
