Re: [mpich-discuss] running parralel job issue(alexandra)
Well yes, the job runs on host2 locally, but parallel execution does the same thing like on host1. Someone here said that if all the computers have the same ip direction it won't work.. Well, every node has 127.0.1.1 As ip, and all of them had same host name till I changed the two of them. Hydra is the default launcher. I also forgot to mencione that ping host2 and same, ping host1 works fine... Sent from my BlackBerry 10 smartphone. From: [email protected] Sent: Wednesday, 23 October 2013 22:42 To: [email protected] Reply To: [email protected] Subject: discuss Digest, Vol 12, Issue 13 Send discuss mailing list submissions to [email protected] To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected] You can reach the person managing the list at [email protected] When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..." Today's Topics: 1. Re: running parallel job issue! (Reuti) 2. Re: running parallel job issue! (Ricardo Rom?n Brenes) 3. Failed to allocate memory for an unexpected message (Luiz Carlos da Costa Junior) 4. Re: Failed to allocate memory for an unexpected message (Antonio J. Pe?a) ---------------------------------------------------------------------- Message: 1 Date: Wed, 23 Oct 2013 17:00:53 +0200 From: Reuti <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] running parallel job issue! Message-ID: <[email protected]> Content-Type: text/plain; charset=iso-8859-1 Am 23.10.2013 um 16:51 schrieb Ricardo Rom?n Brenes:
Hi. I'm not sure how it's done on that version of mpich, but you need to be sure that the mpd daemon is running on both hosts (mpdboot or maybe mpiexec starts it ).
No. The `mpdboot` is gone for some time - nowadays Hydra is used (since MPICH2 v1.3). -- Reuti
Does cpi runs in hosts 2 locally?
On Oct 23, 2013 8:47 AM, "Alexandra Betouni" <[email protected]> wrote:
Hey there, I am trying to set up a parallel invironment with 14 machines, running Linux XUbuntu, connected via ethernet. They all have same IP's and same hostnames. Well I started installing mpich-3.0.4 on a single machine, I run the cpi example on localhost by giving mpiexec -host localhost -n 4 ./examples/cpi and everything worked fine! So I continued changing the hostnames of 2 pc's for a start, and setting up the ssh in these two, also I installed the mpich-3.0.4 on the other machine too. By giving the ssh <othermachine> date commant , I get the date of the other host without giving a password, so I think I passed that step too. Next step was to check if the mpich-3.0.4 runs parallel, so I created a machine file (I made a text file giving the hostnames of the two computers , host1 and host2), and save it in my mpich-3.0.4 build directory. Though when I am trying to parallel run the cpi code by giving mpiexec -n 4 -f machinefile ./examples/cpi on my working directory, I get NO errors but neither parallel job... All processes still running on host1 which is my work station. What am I doing wrong? Thanks
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
------------------------------ Message: 2 Date: Wed, 23 Oct 2013 09:04:29 -0600 From: Ricardo Rom?n Brenes <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] running parallel job issue! Message-ID: <CAG-vK_yyAQ_CNFhYBxqoMniE01HVMA2YxJH=wC79m9KkBDVWFg@mail.gmail.com> Content-Type: text/plain; charset="iso-8859-1" Then the mpiexec should handle it... sorry, I use an outdated version that is in centos repos On Oct 23, 2013 9:01 AM, "Reuti" <[email protected]> wrote:
-- Reuti
participants (1)
Alexandra Betouni
