Re: [mpich-discuss] Help with eclipse juno and mpich2
12 Mar
12 Mar
'13
11:41 a.m.
Hi, If you are using MPICH2 you cannot use the Open MPI compiler wrapper to build your code. If you are using OpenMPI you should contact the OpenMPI developers. Regards, Jayesh ----- Original Message ----- From: "George Papageorgakis" <[email protected]> To: "Jayesh Krishna" <[email protected]> Sent: Monday, March 11, 2013 2:11:02 PM Subject: Re: [mpich-discuss] Help with eclipse juno and mpich2 I have run a hello_mpi on my pc once but since then i get The Open MPI wrapper compiler was unable to find the specified compiler cl.exe in your PATH. Note that this compiler was either specified at configure time or in one of several possible environment variables.
4880
Age (days ago)
4880
Last active (days ago)
0 comments
1 participants
participants (1)
Jayesh Krishna
