Re: [mpich-discuss] Failure to do anything under LSF
Not sure, but looks like it is not able to hold or establish stable socket connection between nodes. -- Hui Zhou From: Sendu Bala via discuss <[email protected]> Date: Wednesday, February 17, 2021 at 9:14 AM To: [email protected] <[email protected]> Cc: Sendu Bala <[email protected]> Subject: [mpich-discuss] Failure to do anything under LSF Hi, We had an mpi app running under LSF that worked fine tiled across 64 hosts. Since moving to a new platform (LSF, but inside an OpenStack cluster*), the app is unreliable when tiled across more than 2 hosts. The likelyhood of failure increases until when tiled across 16 hosts, it almost never works (but still can). It always works when using 16 cores of a single host. The symptoms of failure are that our app doesn’t really start up (it logs nothing), the -outfile-pattern output files don’t get created, and it kills itself after 5mins of apparently doing nothing. (When it works, the -outfile-pattern files are created ~immediately and the app produces output.) When failing, the mpirun process spawns a hydra_pmi_proxy process which spawns the app as well as 15 blaunch processes, which correspond to processes on the 15 other hosts, which have spawned a process for the app each. strace says the mpirun and app processes are doing nothing during the 5mins wait, with the app processes stuck on reading from a socket. After the 5 mins, the mpirun process exits with: strace -p 2526 strace: Process 2526 attached restart_syscall(<... resuming interrupted poll ...>) = ? ERESTART_RESTARTBLOCK (Interrupted by signal) --- SIGINT {si_signo=SIGINT, si_code=SI_USER, si_pid=2498, si_uid=0} --- --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=2530, si_uid=0, si_status=255, si_utime=1, si_stime=0} --- fstat(1, {st_mode=S_IFREG|0640, st_size=0, ...}) = 0 write(1, "[mpiexec@node-name] ", 21) = 21 write(1, "Sending Ctrl-C to processes as r"..., 41) = 41 write(1, "[mpiexec@node-name] ", 21) = 21 write(1, "Press Ctrl-C again to force abor"..., 34) = 34 write(4, "\1\0\0\0\2\0\0\0", 8) = 8 rt_sigreturn({mask=[]}) = -1 EINTR (Interrupted system call) poll([{fd=3, events=POLLIN}, {fd=5, events=POLLIN}, {fd=8, events=POLLIN}, {fd=10, events=POLLIN}, {fd=7, events=POLLIN}, {fd=11, events=POLLIN}, {fd=9, events=POLLIN}, {fd=13, events=POLLIN}, {fd=12, events=POLLIN}, {fd=15, events=POLLIN}, {fd=14, events=POLLIN}, {fd=17, events=POLLIN}, {fd=16, events=POLLIN}, {fd=19, events=POLLIN}, {fd=18, events=POLLIN}, {fd=21, events=POLLIN}, {fd=20, events=POLLIN}, {fd=23, events=POLLIN}, {fd=22, events=POLLIN}, {fd=25, events=POLLIN}, {fd=24, events=POLLIN}, {fd=27, events=POLLIN}, {fd=26, events=POLLIN}, {fd=29, events=POLLIN}, {fd=28, events=POLLIN}, {fd=31, events=POLLIN}, {fd=30, events=POLLIN}, {fd=33, events=POLLIN}, {fd=32, events=POLLIN}, {fd=35, events=POLLIN}, {fd=34, events=POLLIN}, {fd=37, events=POLLIN}, ...], 47, -1) = 6 ([{fd=3, revents=POLLIN}, {fd=15, revents=POLLIN}, {fd=19, revents=POLLIN}, {fd=21, revents=POLLIN}, {fd=25, revents=POLLIN}, {fd=31, revents=POLLIN}]) read(3, "\1\0\0\0\2\0\0\0", 8) = 8 write(6, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(48, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(46, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(38, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(43, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(40, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(45, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(42, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(47, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(50, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(44, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(41, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = 32 write(-1, "\3\0\0\0\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\2\0\0\0", 32) = -1 EBADF (Bad file descriptor) write(2, "[mpiexec@node-name] ", 21) = 21 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=2541, si_uid=0, si_status=255, si_utime=0, si_stime=0} --- write(2, "HYDU_sock_write (utils/sock/sock"..., 41) = 41 write(2, "write error (Bad file descriptor"..., 34) = 34 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=2529, si_uid=0, si_status=255, si_utime=0, si_stime=0} --- write(2, "[mpiexec@node-name] ", 21) = 21 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=2537, si_uid=0, si_status=255, si_utime=0, si_stime=1} --- --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=2528, si_uid=0, si_status=255, si_utime=0, si_stime=2} --- write(2, "HYD_pmcd_pmiserv_send_signal (pm"..., 60) = 60 write(2, "unable to write data to proxy\n", 30) = 30 write(2, "[mpiexec@node-name] ", 21) = 21 write(2, "ui_cmd_cb (pm/pmiserv/pmiserv_pm"..., 42) = 42 write(2, "unable to send signal downstream"..., 33) = 33 write(2, "[mpiexec@node-name] ", 21) = 21 write(2, "HYDT_dmxu_poll_wait_for_event (t"..., 61) = 61 write(2, "callback returned error status\n", 31) = 31 write(2, "[mpiexec@node-name] ", 21) = 21 write(2, "HYD_pmci_wait_for_completion (pm"..., 62) = 62 write(2, "error waiting for event\n", 24) = 24 write(2, "[mpiexec@node-name] ", 21) = 21 write(2, "main (ui/mpich/mpiexec.c:326): ", 31) = 31 write(2, "process manager error waiting fo"..., 45) = 45 exit_group(-1) = ? +++ exited with 255 +++ The bsub -e file says the corresponding: [mpiexec@node-name] HYDU_sock_write (utils/sock/sock.c:254): write error (Bad file descriptor) [mpiexec@node-name] HYD_pmcd_pmiserv_send_signal (pm/pmiserv/pmiserv_cb.c:176): unable to write data to proxy [mpiexec@node-name] ui_cmd_cb (pm/pmiserv/pmiserv_pmci.c:42): unable to send signal downstream [mpiexec@node-name] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [mpiexec@node-name] HYD_pmci_wait_for_completion (pm/pmiserv/pmiserv_pmci.c:160): error waiting for event [mpiexec@node-name] main (ui/mpich/mpiexec.c:326): process manager error waiting for completion The issue isn’t specific to our app; I get the same symptoms with: bsub -q normal -o bsub.o -e bsub.e -R"span[ptile=1]” -n16 mpirun mpich/examples/cpi bsub.e is empty, and bsub.o has this: [mpiexec@node-name] Sending Ctrl-C to processes as requested [mpiexec@node-name] Press Ctrl-C again to force abort […] Your job looked like: ------------------------------------------------------------ # LSBATCH: User input mpirun mpich/examples/cpi ------------------------------------------------------------ Exited with exit code 141. Resource usage summary: CPU time : 0.49 sec. Max Memory : 85 MB Average Memory : 70.89 MB Total Requested Memory : - Delta Memory : - Max Swap : - Max Processes : 63 Max Threads : 80 Run time : 310 sec. Turnaround time : 317 sec. (I did not initiate any Ctrl-C or similar myself.) This is with mpich-3.4.1 configured --with-device=ch4:ucx. It’s worth noting I get the exact same symptoms using latest OpenMPI as well, so this is not an mpich-specific issue. What can I do to investigate further or try to resolve this, so it works reliably with 16 or ideally 64 hosts again? [*] I know very little about networking, but I’m told we have new nodes in the LSF cluster that use a software-defined network, but also old nodes that use a hardware network like our old system; limiting to the old nodes doesn’t help. But maybe there are some subtleties here I’ve overlooked. Cheers, Sendu -- The Wellcome Sanger Institute is operated by Genome Research Limited, a charity registered in England with number 1021457 and a company registered in England with number 2742969, whose registered office is 215 Euston Road, London, NW1 2BE.
participants (1)
Zhou, Hui
