Re: [mpich-discuss] Shared Memory Segfaults
I can reproduce the segfault with the latest mpich. In Clean_List(), I think there is a data race, since all shmem members update the head node head->next_win = temp_win; head->next = temp_next; I tried to simplify Clean_List() further as follows, void Clean_List() { Node *cur_node = head; MPI_Win cur_win = head_win; Node *next_node; MPI_Win next_win; while (cur_node) { next_node = cur_node->next; next_win = cur_node->next_win; MPI_Win_free(&cur_win); cur_node = next_node; cur_win = next_win; } head = tail = NULL; } But I still met segfault. With gdb, the segfault disappears. If I comment out the call to Clean_List in main(), the error also disappear. I Cc'ed our local RMA expert Xin to see if she has new findings. --Junchao Zhang On Sat, May 2, 2015 at 10:26 AM, Brian Cornille <[email protected]> wrote:
Hello,
In working on a project that is attempting to use MPI shared memory (from MPI_Win_allocate_shared) I began getting inconsistent segfaults in portions of the code that appeared to have no memory errors when investigated with gdb. I believe I have somewhat reproduced this error in a small code (attached) that creates a linked list of MPI shared memory allocated elements.
The attached program segfaults for me when run with more than one process. However, will not segfault if run in gdb (e.g. mpirun -n 2 xterm -e gdb ./mpi_shmem_ll). I have done what I can to eliminate any apparent race conditions. Any help in this matter would be much appreciated.
Thanks and best,
Brian Cornille
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
