Re: [mpich-discuss] Can't receive messages
On 12/31/2013 04:34 PM, Pavan Balaji wrote:
Are matze-debian and notebook of the same architecture (x86_64 and running the same OS/configuration)?
� Pavan
No, notebook is x86_32 on debian stable and matze-debian is x86_64 on debian testing, but I compiled the program for each system separately. Matze
On Dec 31, 2013, at 9:26 AM, Matthias Neuer <[email protected]> wrote:
On 12/30/2013 03:23 PM, Rajeev Thakur wrote:
There must be a firewall issue. A process on one machine cannot open a TCP connection on the other machine. Only known services like ssh are working.
I don't think I have any firewall filter rule in my configuration. "iptables --list" shows on both machines
Chain INPUT (policy ACCEPT) target prot opt source destination
Chain FORWARD (policy ACCEPT) target prot opt source destination
Chain OUTPUT (policy ACCEPT) target prot opt source destination
Do you know a log file I can check to find out if the package was refused?
Thanks for your help
On Dec 30, 2013, at 6:43 AM, Matthias Neuer <[email protected]> wrote:
On 12/30/2013 12:12 PM, Rajeev Thakur wrote:
There may be some other connectivity issue between the machines. Does the cpi example from the MPICH examples directory run across the two machines?
The cpi-example hangs too. Output:
Process 1 of 4 is on matze-debian Process 3 of 4 is on matze-debian Process 2 of 4 is on notebook Process 0 of 4 is on notebook
Then it hangs. Seems like a configuration issue but why are the printf messages transfered correctly?
Matthias
On Dec 30, 2013, at 3:58 AM, Matthias Neuer <[email protected]> wrote:
Hi.
Unfortunately, this does not solve the problem.
Maybe I should have written that the program hangs after the output in my last post. It waits until MPI_Recv returns which does not happen.
By the way I can login from one machine to the other using ssh, no problem.
Thanks
On 12/30/2013 06:39 AM, Rajeev Thakur wrote:
Try adding an fflush(stdout) after the printf after the recv.
On Dec 29, 2013, at 12:50 PM, Matthias Neuer <[email protected]> wrote:
-------- Original Message -------- Subject: Can't receive messages Date: Sun, 29 Dec 2013 19:00:05 +0100 From: Matthias Neuer <[email protected]> To: [email protected]
Hi.
I installed MPICH on 2 machines (called notebook and matze-debian) using the same sourcecode. The output of mpichversion is both times:
MPICH Version: 3.0.4 MPICH Release date: Wed Apr 24 10:08:10 CDT 2013 MPICH Device: ch3:nemesis MPICH configure: --disable-f77 --disable-fc --prefix=/home/matze/mpich-install MPICH CC: cc -O2 MPICH CXX: c++ -O2 MPICH F77: no MPICH FC: no
I wrote a small test program which I send as an attachment. On execution on the machine matze-debian I get the following:
Process 0 is on matze-debian Process 2 is on matze-debian Process 1 is on notebook received: Hello, from number 2 on matze-debian Process 2 has sent the message Process 1 has sent the message
I don't receive the message from process number 1, but the output suggests that the message was succesfully sent. Actually I checked the network traffic using wireshark and matze-debian received a package in which I found the sent message. So somehow the program does not recognize the arrival of the message.
When I run the program on a single machine it works.
I don't know if this is a programming error or a configuration error.
<ex1.c>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Matthias Neuer
