Re: [mpich-discuss] Problem with MPICH 3.0 rc1 compilation on RHEL 5
Hi, Dave! Thank you for notice! Somehow latest nightly build listed on http://www.mpich.org/static/tarballs/nightly/trunk/ is from January 4. Eugene. ________________________________________ From: [email protected] [[email protected]] On Behalf Of Dave Goodell [[email protected]] Sent: Friday, January 11, 2013 3:50 PM To: [email protected] Subject: Re: [mpich-discuss] Problem with MPICH 3.0 rc1 compilation on RHEL 5 FYI, the LLONG_MAX issue was resolved recently: http://git.mpich.org/mpich.git/commitdiff/465ca32 Expect to see this in an upcoming MPICH bug release, likely named v3.0.2. -Dave On Nov 14, 2012, at 4:46 PM CST, Dave Goodell wrote:
This is because you have selected a bare "--enable-strict" option to configure, which defaults to c89. I'll see if there's a more pleasant way around this, but in the meantime is it acceptable for you to pass "--enable-strict=c99" instead?
The problem occurs because your compiler still responds to the "long long" type but disables the "LLONG_MAX" constant when asked for c89 mode.
-Dave
On Nov 14, 2012, at 4:14 PM CST, Yauheni Zelenko wrote:
Hi!
I'm trying to compile MPICH 3.0 rc1 on Red Hat Enterprise Linux 5 and compilation failed because of undefined LLONG_MAX.
LLONG_MAX definition in /usr/include/limits.h is depend on C99 condition. -std=c89 is passed to GCC.
My configure options:
./configure --prefix=${InstallDir} \ --with-pm=hydra --with-device=ch3:nemesis \ --disable-chekpointing \ --enable-strict --enable-fast=O3 \ --disable-f77 --disable-fc \ CC=/grid/common/pkgs/gcc/v4.4.5/bin/gcc CFLAGS="-m32 -fPIC" \ CPP=/grid/common/pkgs/gcc/v4.4.5/bin/cpp \ CXX=/grid/common/pkgs/gcc/v4.4.5/bin/g++ CXXFLAGS="-m32 -fPIC" \ CXXCPP=/grid/common/pkgs/gcc/v4.4.5/bin/cpp
GCC 4.4.5 is also produce next warnings:
mpi-io/write.c: In function 'MPIOI_File_write': mpi-io/write.c:126: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/write_all.c: In function 'MPIOI_File_write_all': mpi-io/write_all.c:109: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/write_allb.c: In function 'MPIOI_File_write_all_begin': mpi-io/write_allb.c:105: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/write_ord.c: In function 'PMPI_File_write_ordered': mpi-io/write_ord.c:98: warning: assignment discards qualifiers from pointer target type mpi-io/write_ord.c:100: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/write_ordb.c: In function 'PMPI_File_write_ordered_begin': mpi-io/write_ordb.c:104: warning: assignment discards qualifiers from pointer target type mpi-io/write_ordb.c:106: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/write_sh.c: In function 'PMPI_File_write_shared': mpi-io/write_sh.c:100: warning: assignment discards qualifiers from pointer target type mpi-io/write_sh.c:102: warning: passing argument 1 of 'MPIU_external32_buffer_setup' discards qualifiers from pointer target type ./adio/include/mpiu_external32.h:20: note: expected 'void *' but argument is of type 'const void *' mpi-io/mpiu_external32.c: In function 'MPIU_write_external32_conversion_fn': mpi-io/mpiu_external32.c:24: warning: implicit declaration of function 'MPIR_Datatype_iscontig' mpi-io/mpiu_external32.c:24: warning: nested extern declaration of 'MPIR_Datatype_iscontig' mpi-io/mpiu_external32.c: In function 'MPIU_datatype_full_size': mpi-io/mpiu_external32.c:123: warning: unused variable 'extent' ./pm/pmiserv/pmip_cb.c: In function 'parse_exec_params': ./pm/pmiserv/pmip_cb.c:808: warning: null argument where non-null required (argument 1) ./pm/pmiserv/pmip_cb.c:808: warning: null argument where non-null required (argument 1) ./pm/pmiserv/pmip_cb.c:808: warning: null argument where non-null required (argument 2) ./pm/pmiserv/pmip_cb.c:808: warning: null argument where non-null required (argument 2) src/mpi/datatype/status_set_elements.c: In function 'PMPI_Status_set_elements': src/mpi/datatype/status_set_elements.c:54: warning: unused variable 'size' src/mpi/datatype/status_set_elements_x.c: In function 'MPIR_Status_set_elements_x_impl': src/mpi/datatype/status_set_elements_x.c:41: error: 'LLONG_MAX' undeclared (first use in this function) src/mpi/datatype/status_set_elements_x.c:41: error: (Each undeclared identifier is reported only once src/mpi/datatype/status_set_elements_x.c:41: error: for each function it appears in.)
Eugene. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Yauheni Zelenko
