Re: [mpich-discuss] mpich install error (libstdc++.so)
Hi Min, You may want to see my config.log file while configuring MPICH. Here it is. It seems that there are some intel compiler path. But I am not sure whether they affect my make. Thank you Zhifeng On Thu, Oct 18, 2018 at 1:23 PM Zhifeng Yang <[email protected]> wrote:
Hi Min,
Thank you very much for your help. Now I installed MPICH successfully.
However, when I use it for another weather model. It has the following error.
time mpif90 -w -ffree-form -ffree-line-length-none -fconvert=big-endian -frecord-marker=4 -fopenmp -o test_io_idx test_io_idx.f -L. -lwrfio_int
real 0m0.234s user 0m0.076s sys 0m0.042s if [ -f ../../frame/pack_utils.o -a -f ../../frame/clog.o ] ; then \ time mpif90 -w -ffree-form -ffree-line-length-none -fconvert=big-endian -frecord-marker=4 -fopenmp -I../ioapi_share -o diffwrf diffwrf.f \ ../../frame/pack_utils.o ../../frame/module_internal_header_util.o ../../frame/module_driver_constants.o ../../frame/module_machine.o ../../frame/module_wrf_error.o ../../frame/wrf_debug.o libwrfio_int.a ; \ fi /umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/mpich-3.2.1/lib/libmpi.so: undefined reference to `_intel_fast_memset' /umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/mpich-3.2.1/lib/libmpi.so: undefined reference to `_intel_fast_memcpy' /umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/mpich-3.2.1/lib/libmpi.so: undefined reference to `__intel_sse2_strlen' /umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/mpich-3.2.1/lib/libmpi.so: undefined reference to `__intel_sse2_strncmp' collect2: error: ld returned 1 exit status 0.03user 0.06system 0:00.31elapsed 31%CPU (0avgtext+0avgdata 9716maxresident)k 144inputs+48outputs (0major+10999minor)pagefaults 0swaps make[3]: [test_io_idx] Error 1 (ignored) make[3]: Leaving directory `/umbc/xfs1/zzbatmos/users/vy57456/model/gfortran/wrfchem4_0_c/WRF/external/io_int'
It seems that I used ifort to compile MPICH. But I used gfortran. Any help?
Zhifeng
On Thu, Oct 18, 2018 at 10:19 AM Si, Min <[email protected]> wrote:
Hi Zhifeng,
It looks like the Intel c++ compiler icpc is used for linking. Maybe you did not specify `CXX=g++` at configure time.
Please try this (make sure all compilers are with the same version) ./configure <other config options> CC=gcc CXX=g++ FC=gfortran F77=gfortran
If you still see the installation error, please send us the config.log at your build directory together with the error message.
Min On 2018/10/18 8:28, Zhifeng Yang wrote:
Hi
I tried to install mpich using gcc. However, while make, I got the following error message.
libtool: link: icpc -shared src/binding/cxx/.libs/initcxx.o -Wl,-rpath,/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/lib/.libs -Wl,-rpath,/cm/shared/apps/gcc/4.8.4/lib/../lib -Wl,-rpath,/home/vy57456/zzbatmos_user/application/gfortran/mpich-3.2.1/lib -Wl,-rpath,/cm/shared/apps/gcc/4.8.4/lib/../lib lib/.libs/libmpi.so -lpthread -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/../compiler/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/compiler/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/mkl/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/tbb/lib/intel64/gcc4.4 -L/cm/shared/apps/slurm/14.11.11/lib64/slurm -L/cm/shared/apps/slurm/14.11.11/lib64 -L/usr/cluster/contrib/hdf5/install-1.8.16/lib -L/cm/shared/apps/acml/current/ifort64/lib -L/cm/shared/apps/slurm/14.11.11/lib64/../lib64 -L/cm/shared/apps/slurm/14.11.11/lib64/../lib64/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../lib64 -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/../compiler/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/compiler/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/mkl/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/tbb/lib/intel64/gcc4.4/ -L/cm/shared/apps/slurm/14.11.11/lib64/slurm/ -L/cm/shared/apps/slurm/14.11.11/lib64/ -L/usr/cluster/contrib/hdf5/install-1.8.16/lib/ -L/cm/shared/apps/acml/current/ifort64/lib/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -limf -lirng -lm -lipgo -ldecimal -lcilkrts /cm/shared/apps/gcc/4.8.4/lib/../lib/libstdc++.so -lintlc -lsvml -lgcc -lgcc_s -lirc_s -ldl -lc -O2 -Wl,-soname -Wl,libmpicxx.so.12 -o lib/.libs/libmpicxx.so.12.1.1 /cm/shared/apps/gcc/4.8.4/lib/../lib/libstdc++.so: could not read symbols: File in wrong format make[2]: *** [lib/libmpicxx.la] Error 1 make[2]: Leaving directory `/umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/source_code/mpich-3.2.1' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/source_code/mpich-3.2.1' make: *** [all] Error 2
Do you have any experience on this error? Thank you
Zhifeng
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe:https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Zhifeng Yang
