Re: [mpich-discuss] Issues with shared memory window
Jonathan, There are several errors in the code. Why is the window malloc(0)’ed? The window is created by Win_allocate_shared. You need to do a barrier after all accesses to the window. Otherwise, another process might free the shared memory while you are accessing it. You need to have a bunch of Win_sync’s after each process has done its writes and before processes do their reads. You need to free the Window using MPI_Win_free. You should free your communicator, otherwise it’s a resource leak. The argument to be passed for your array should be &arr, not arr, since arr is an OUT parameter. I’d recommend taking one of the code examples in test/mpi/rma and modifying it to what you need. That way the code would be standard compliant. Regards, — Pavan On Jul 25, 2014, at 11:07 PM, Jonathan Blair <[email protected]> wrote:
Hi MPICH users,
I've been having issues with MPI_Win_allocate_shared(). I believe my use case is compliant with the standard, but I am not ruling out ignorance on my part as the fault.
In my project, one task allocates the memory to be shared, and the other tasks attach to the shared memory. The allocation function returns MPI_SUCCESS, as do all calls of MPI_Win_shared_query(). The size and displacement unit match expected values. However, the picture of the memory is nonuniform.
I'm running this on a shared memory system (the communicator is intra-node, currently being tested on a desktop), with MPICH 3.1.2 installed, passing all internal tests during installation.
I notice that MPI_Free_mem() reports errors and I believe MPI_Finalize() causes a segfault, but I'm not sure if this is specifically related to the issue at hand.
I have included a minimal test case below. Does anyone have any insight into my problem?
Thanks for you input, Jonathan
[begin file test.cpp] #include <stdlib.h> #include <stdio.h> #include <mpi.h>
using namespace std;
int main(int argc, char *argv[]){
int rank; int color = 1; int ierr; int *arr = (int *) malloc( 0 ); int disp_unit;
MPI_Aint size = 2048; MPI_Aint reportedSize = 0; MPI_Comm comm;
ierr = MPI_Init( &argc, &argv ); ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); ierr = MPI_Comm_split( MPI_COMM_WORLD, color, rank, &comm );
MPI_Win *win = (MPI_Win *) malloc( 0 );
if (rank == 0){ ierr = MPI_Win_allocate_shared( \ size, \ (int) sizeof(int), \ MPI_INFO_NULL, \ comm, \ (void *) arr, \ win );
printf( "Rank: %i ierr from MPI_Win_allocate_shared = %i\n", rank, ierr);
ierr = MPI_Barrier( comm );
for (int i=0; i < size; i++){ arr[i] = i; }
printf( "Rank: %i arr[0] = %i, arr[1] = %i\n", rank, arr[0], arr[1] );
ierr = MPI_Barrier( comm ); } else{ ierr = MPI_Win_allocate_shared( \ (MPI_Aint) 0, \ (int) sizeof(int), \ MPI_INFO_NULL, \ comm, \ (void *) arr, \ win );
ierr = MPI_Win_shared_query( \ *win, \ (int) 0, \ &reportedSize, \ &disp_unit, \ (void *) arr );
printf( "Rank: %i ierr from MPI_Win_shared_query = %i\n", rank, ierr); printf( "Rank: %i reportedSize = %i\n", rank, (int) reportedSize); printf( "Rank: %i disp_unit = %i\n", rank, disp_unit);
ierr = MPI_Barrier( comm ); printf( "Rank: %i arr[0] = %i, arr[1] = %i\n", rank, arr[0], arr[1] ); }
MPI_Free_mem((void *) win); ierr = MPI_Finalize(); return 0; } [end file test.cpp]
[begin shell output] $ mpirun -n 2 ./test Rank: 0 ierr from MPI_Win_allocate_shared = 0 Rank: 1 ierr from MPI_Win_allocate_shared = 0 Rank: 1 ierr from MPI_Win_shared_query = 0 Rank: 1 reportedSize = 2048 Rank: 1 disp_unit = 4 Rank: 0 arr[0] = 0, arr[1] = 1 Rank: 1 arr[0] = 1996775424, arr[1] = 32592 [0] Block at address 0x000000000093f190 is corrupted; cannot free; may be block not allocated with MPL_trmalloc or MALLOC called in /path/to/mpich-3.1.2/src/mpid/ch3/src/ch3u_rma_ops.c at line 493 [1] Block at address 0x0000000000ec8190 is corrupted; cannot free; may be block not allocated with MPL_trmalloc or MALLOC called in /path/to/mpich-3.1.2/src/mpid/ch3/src/ch3u_rma_ops.c at line 493 [1] 56 at [0x0000000000eccb78], ich-3.1.2/src/util/wrappers/mpiu_shm_wrappers.h[188] [1] 24 at [0x0000000000eccab8], ich-3.1.2/src/util/wrappers/mpiu_shm_wrappers.h[217] [1] 56 at [0x0000000000ecc9d8], ich-3.1.2/src/util/wrappers/mpiu_shm_wrappers.h[188] [1] 24 at [0x0000000000ecc918], ich-3.1.2/src/util/wrappers/mpiu_shm_wrappers.h[217] [1] 8 at [0x0000000000ecc788], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[131] [1] 8 at [0x0000000000eca3a8], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[127] [1] 8 at [0x0000000000ec74e8], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[123] [1] 16 at [0x0000000000ecc6c8], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[120] [1] 16 at [0x0000000000ecc608], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[117] [1] 16 at [0x0000000000ecc548], src/mpid/ch3/channels/nemesis/src/ch3_win_fns.c[113] [1] 48 at [0x0000000000ecbe98], h/mpich/mpich-3.1.2/src/mpid/ch3/src/mpid_rma.c[301] [1] 32 at [0x0000000000ecc478], ch/mpich/mpich-3.1.2/src/mpid/ch3/src/mpid_vc.c[122] [1] 8 at [0x0000000000ecc2f8], mpich/mpich-3.1.2/src/util/procmap/local_proc.c[93] [1] 8 at [0x0000000000ecc248], mpich/mpich-3.1.2/src/util/procmap/local_proc.c[92] [1] 32 at [0x0000000000ecc3a8], ch/mpich/mpich-3.1.2/src/mpid/ch3/src/mpid_vc.c[122] [1] 8 at [0x0000000000ecc198], mpich/mpich-3.1.2/src/util/procmap/local_proc.c[93] [1] 8 at [0x0000000000ecc0e8], mpich/mpich-3.1.2/src/util/procmap/local_proc.c[92] [1] 32 at [0x0000000000ecc018], ch/mpich/mpich-3.1.2/src/mpid/ch3/src/mpid_vc.c[122] [1] 504 at [0x0000000000ecafc8], earch/mpich/mpich-3.1.2/src/mpi/comm/commutil.c[281] [1] 504 at [0x0000000000ecaa88], earch/mpich/mpich-3.1.2/src/mpi/comm/commutil.c[281]
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 8822 RUNNING AT Machine = EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions [end shell output] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
participants (1)
Balaji, Pavan
